Originally Posted By: chevyboy14
All you really need to replace is the strut but sometimes the bearing falls to pieces when you remove it. If it was mine I'd just buy struts and the mount. And rent a spring compressor. It's easy to do and for both front it might take you and extra 15-20 mins. So its worth the money saved imo. I would buy the mount that way if they look worn or anything you can replace and you may very well pull then apart and say wow they still look good ill take the new I ones I bought back and save 60 + bucks or you may say I already got the new ones ill just use them. You probably dont need the spring or the bellows boot the boot doesn't see a hard life. Other than convenience I cannot see why you would need a complete assembly . But im cheap and don't like spending money
I hear you, but when a complete new assy is so cost effective, why bother? See this guys post - he hits the nail right on the head:
Originally Posted By: 951Indy
Bare strut = $60. Mount with bearing = $60. Bellows/bumper = $15 Spring seat = $15 Coil spring = $35
Total = $185 each plus the pleasure of taking it all apart and putting back together. If you choose to take it apart to see which parts are needed, the local prices, tax, and running around will make the price go up quickly.
Quick strut = $122 no tax, and shipped for free. No checking any parts, no running around for anything, and predictable "down time". 15-20 minutes per side to install, most of which is getting the jack and stands under the car.
You may not NEED a new bearing, spring, bellows, seat, etc but with high miles, why debate. This assumes a quick strut is available for the car, which in the OP's case, it is.
