Originally Posted By: ckard
The manual calls for dino 10W30 but I like to switch to synthetic, the engine uses about 1/2 qt every 1000 miles from what I was told, what's the best synthetic to use, what grade, or should I stick to dino? It's a Dodge 1500 V8 (not Hemi) truck and it is in very good shape, I'd like to use it for several years. TIA.
I ran M1 10w30 for years and years and years in my 318 (5.2), no problems at all. If I had to do that today and it was burning a quart every 2000 miles like yours, I'd give Rotella T6 5w40 synthetic a try. Your 96 is roller cammed and doesn't crave ZDDP or anything so you don't need RT6 for the additive levels, but its also a fairly economical way to get into a slightly heavier grade synthetic than 10w30. I've also found on my Jeeps that RT6 weeps out the main seals slightly less than M1 synthetics for whatever reason.
