Had my oil changed through Audi's maintenance plan.
For the last 3000 miles, I've run Pennzoil Ultra 5W40 and I believe the dealer uses Castrol Syntec LLX 5w40.
I noticed my oil temp went up by 15-20 degrees F for about 200 miles after the oil change.
The oil temp increase has slowly been creeping down to about a 10-15 degree increase over the last couple of hundred miles.
I've noticed the oil temp increase is most obvious when I drive moderately hard. It will go up to 235 sometimes and then only settles back down to 217-222, at idle.
My best guess is the Castrol 5w40 used by the dealer must be thicker than what I normally use, (Pennzoil Ultra 5W40) = increased heat.
Thoughts? Anything I should worry about?
