Originally Posted By: grampi
I just ordered a LED light kit. Chasing electrical gremlins can be time consuming and I don't have time to mess with it.
If they are indeed electrical gremlins as I (and others) suspect they are, you'll just blow the LED's.
I think the electrical gremlins are isolated to the trailer wiring, so replacing the entire wiring kit should cure the problem. I don't have any electrical problems with the vehicle.
Good enough, I assumed when you mentioned an LED kit that it only included the lights themselves. If they include the complete wiring you should be able to rule out the trailer wiring as the source of the problem.
Just make sure any spots on the trailer where wires enter or exit the frame rails that there are no sharp edges where the wires can fray.
