Originally Posted By: HTSS_TR
I use 2.5 gallon liquid detergent containers to store used oils. When I filled up 2-3 containers I took it to recycle centers, usually parts store, quick lube ...
It's strange, out here, I've tried that with detergent/milk/antifreeze/brake fluid jugs, and the one time they actually turned me AWAY because they said the oil was not in an "approved container" or something.....Walmart said it had to be in an "oil container".....I can sort of understand the detergent bottle, because the laundry soap has that "lingering film" that technically "could" mess up their used oil collection tank, being mixed with detergent fragments......but a MILK jug? That's easily rinsable, provided it's not from spoiled milk or some such
So anyways, I just took it to the city dump, and they recycled it no problem!
Originally Posted By: ChrisJH
Am I nuts because I bought one of those oil drain pans with the drain plugs on it?
Nope, not at all...though I have heard complaints of the "Blitz!" brand of oil storage containers "leaking" from that little threaded spout......I've heard the most complaints for the "smaller" drainage container, the one with the 5-9" diameter screw top lid, which has a convenient "screen" to catch the drain plug/washer should you lose hold of it
But the larger (I think it's 15 qt) with the angled "handle" that protrudes out and the plastic cap, I've heard those are a bit more sturdier, and less prone to leakage.....even has a neat little "oil filter indention" where you sit the filter, gasket-side down to drain out.
