Originally Posted By: yuri2002
Hi, I need to change the gear oil in my 79 Trans am. It has the Borg Warner Super T10 4 speed transmission. Should I use Redline 75W90 NS synthetic oil GL5 oil? Is synthetic oil okay to use in the older super t10 transmission? ThankS!
I would use either Redline MTL or MTL90. Synthetic is fine in your T10. For the record I use MTL in my Muncie M21, it sees track and street duty, going on 14 years now with MTL. Do not use a GL5, it will shift poorly.
