Originally Posted By: swirlparanoid
i had a topic similar to this a while back and it was concluded that nothing would really happen as long as oil was up to temp. but something i thought of after i made that thread was the affects of a redline shift on a transmission. it is widely said on here that an engine will outlast a car but the same thing is never said about an auto trans, would an engine redlining have a negative affect on a trans over the years? i would imagine it couldn't really help its longevity to do so....
Depends on the engine/trans combo. TH400 behind a big block...then a redline shift means that the trans has to handle nearly full engine torque...But a modern engine with drive by wire and electronic transmission will remove engine power (through fuel or timing management) during the shift, greatly reducing the transmission load during a redline shift.
I wouldn't make a habit of redlining the car, but if the engine temp, and oil temp, are warm and stable, you're minimising the adverse impact...do it cold, you're asking for trouble...
