Brake Caliper Dampers?
by HangFire. 01/18/19 11:32 AM
Fully Formulated Coolant and old radiator
by Wheel. 01/18/19 11:27 AM
'15 6.7 Powerstroke UOA
by roadrunner1. 01/18/19 10:18 AM
Automotive Battery Voltage -What is ur reading?
by Patrick0525. 01/18/19 10:10 AM
Amsoil 0w-40 vs 5w-40
by Buddyp. 01/18/19 10:07 AM
M1 is changing their oils, site and adding a new oil
by Flashlightboy. 01/18/19 10:01 AM
Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
100 registered members (2019StingrayZ51, andyd, badtlc, Best F100, Black_Thunder, 15 invisible), 2,224 guests, and 41 spiders.
Topics296,781
Posts4,958,806
Members66,969
Most Online2,577
Jan 14th, 2019
GM 3.4L V6? #2386487
09/24/11 10:42 AM
09/24/11 10:42 AM
Ankeny, IA
renegade_987 Offline OP
Ankeny, IA
Mu uncle just adopted a Monte Carlo (2001) with this engine. I have ZERO experiance with it, is it any good? I know it has a similar engine to the Grand AM. Thing is, it has 175K on her so I'm not sure how they hold up. Opinions welcome! TIA
2015 VW Jetta 1.8t - Pennzoil Euro/VW OEM
2004 F150 - Valvoline WB/Motorcraft
2008 HHR - Mobil 1 / WIX
2005 500 - Citgo Synthetic/Fram XG
Re: GM 3.4L V6? [Re: renegade_987] #2386494
09/24/11 10:54 AM
09/24/11 10:54 AM
New York
pbm Offline
pbm  Offline
New York
It's a bored out 3.1 60* V6.
They were prone to intake-manifold gasket failures.
If the gasket is replaced with a Fel-Pro Problem Solver they are capable of high mileage. (I have seen several on here with over 300K and one owner claimed 800K...although he claimed they need an I-M gasket every 200K regardless ....)
They are also economical if not powerful. I have gotten well over 30mpg highway with my 3.1 on long trips.
'Journalism is Dead'
Re: GM 3.4L V6? [Re: pbm] #2386496
09/24/11 10:57 AM
09/24/11 10:57 AM
Michigan
daves87rs Offline
daves87rs  Offline
Michigan
Originally Posted By: pbm
It's a stroked (or maybe bored out) 3.1 60* V6.
This....
2019 Chevrolet Equinox LS
2006 Chevrolet Cobalt LS
Re: GM 3.4L V6? [Re: renegade_987] #2386497
09/24/11 10:57 AM
09/24/11 10:57 AM
ME
eljefino Offline
eljefino  Offline
ME
I liked mine in my silhouette. It was noisy when cold but torquey and got 26 MPG going extra legal speeds with the AC on and a van full of stuff. It matches the 4 speed auto they stick beside it perfectly.
Re: GM 3.4L V6? [Re: renegade_987] #2386503
09/24/11 11:01 AM
09/24/11 11:01 AM
Milwaukee, WI.
beechcraftted Offline
Milwaukee, WI.
The GM 3.4 is a very study engine except for one thing: the lower intake manifold gaskets. Commonly referred to as the LIM. At that mileage, I'm sure they've been replaced at least once. If the repair was done with Fel-Pro gaskets, you'll never have to do it again. If you keep coolant out of the oil, these engines have been able to top 250 K pretty easily. They are also known for some clatter/tick upon cold start. This generally goes away within 30 seconds. Most just ignore it, it is a trait of this engine and fades with warmup. I use HDEO 15W40 in the summer and the recommended 5W-30 in the winter.
'66 Chevelle 496 big block
'69 Corvette 427 4 speed
'70 Rebel "Machine" 390 4 speed
'04 Suburban
'10 Impala
'15 Honda F6B
'92 Suzuki Katana 1100
Re: GM 3.4L V6? [Re: renegade_987] #2386508
09/24/11 11:05 AM
09/24/11 11:05 AM
New York
pbm Offline
pbm  Offline
New York
...I should have added to tell your uncle keep his eyes on the coolant tank level as loss of coolant is the main sign of I-M leakage. It might be wise to throw a bottle of Barsleaks in it until you ascertain whether it's leaking.
It's not a matter of 'if' it will leak but rather of 'when'....
Mechanics are familiar with the job and many will do it for less than $600...(maybe even less in Iowa)..
Re: GM 3.4L V6? [Re: pbm] #2386540
09/24/11 11:47 AM
09/24/11 11:47 AM
Joplin
Cressida Offline
Cressida  Offline
Joplin
If you have no records that the LIM gasket has already been replaced then I would do an oil analysis to see how much coolant is in the oil.
You can not see the coolant in the oil so you are wasting your time doing a visual on the oil. The lab called me back with the bad news.
Some of these engines (including mine) also have had problems with head gaskets but that may be related to the LIM and Dexcool.
I changed the coolant to G-05 after doing the LIM twice and the heads.
Re: GM 3.4L V6? [Re: renegade_987] #2386562
09/24/11 12:08 PM
09/24/11 12:08 PM
SF Bay Area
EricF Offline
EricF  Offline
SF Bay Area
the factory LIM gasket is plastic which the dexcool's 2-EHA eats up over time. So felpro's updated gasket solves the issue.
these motors have a lot of oomph as well as reliability (aside from the intake gasket)
They're relatively easy to work on too.
1993 Ford Ranger XLT 4.0L 4x4 (240k) 5W-30 Synpower
2006 Saturn Relay-3 3.5L (85k) 5W-30 Synpower
2012 Ford Fusion SE 2.5L (39k) 5W20 M/C Semi Syn
Re: GM 3.4L V6? [Re: EricF] #2389663
09/27/11 05:15 PM
09/27/11 05:15 PM
PA
ridgerunner Offline
ridgerunner  Offline
PA
My wife's grand am has had a steady diet of 1985 10-40 oil lately without complaint. Gotta be a tough engine!
Re: GM 3.4L V6? [Re: ridgerunner] #2389729
09/27/11 06:04 PM
09/27/11 06:04 PM
ohio
caravanmike Offline
caravanmike  Offline
ohio
lol
Oils I use: Any 5w-30,5w-20 conventional
Re: GM 3.4L V6? [Re: renegade_987] #2389867
09/27/11 08:17 PM
09/27/11 08:17 PM
Upstate NY
sciphi Offline
sciphi  Offline
Upstate NY
They're one tough engine. There are two 3400's in older GM minivans that are still running okay despite lifetimes of indifferent at best maintenance. They sound like death warmed over when first started, but they go and get mid-20's fuel economy.
In a lighter Monte Carlo, they should be capable of 30+ mpg highway when driven sensibly.
2013 Toyota RAV4 XLE
2012 Chevrolet Cruze Eco
Re: GM 3.4L V6? [Re: renegade_987] #2389952
09/28/11 04:29 AM
09/28/11 04:29 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
I agree. This motor is proof that the much ballyhooed "piston slap" issue is the biggest non-problem in history!
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: GM 3.4L V6? [Re: renegade_987] #2390134
09/28/11 09:17 AM
09/28/11 09:17 AM
Florida
artificialist Offline
Florida
I have replaced head gaskets often on this engine.
I don't like the 2.8/3.1/3.4 engines.
2010 Lancer Ralliart Sportback
Re: GM 3.4L V6? [Re: artificialist] #2390144
09/28/11 09:26 AM
09/28/11 09:26 AM
New England
cchase Offline
cchase  Offline
New England
I hear this often - and wonder whether there is a connection between head gasket failure and a previous LIM gasket failure resulting in an overheating condition and subsequently compromised head gasket...
Re: GM 3.4L V6? [Re: renegade_987] #2390201
09/28/11 10:37 AM
09/28/11 10:37 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
Yet it's actually a relatively small amount of the engines produced that require new LIM and/or head gaskets.
Fel Pro Problem Solver (hint).
