I drive a 2011 Tundra 5.7 with TRD Supercharger approx 510hp / 550tq.
Initially my first oil change they used conventional as this is what is recommended 5w/20.
5.7L V8 (3UR-FE, 3UR-FBE) engine
Oil grade: ILSAC multigrade engine oil
Recommended viscosity: SAE 5W-20 or 0W-20
SAE 5W-20 or 0W-20 engine oil
may be used. However, SAE
0W-20 is the best choice for
good fuel economy and good
starting in cold weather.
Now with the supercharger I feel as if I should run synthetic more boost and more power, synthetic will help protect my engine yes?
Also I have been running 93 octane as premium is required absolutely. I just put Chevron 93 in and it has a bit of a ping, but when I run VPOWER it doesn't ping at all..what gives?
I guess I need to know what is a good booster additive I can run every other tank to make sure I am running the best I can. The dealership said everything is checking out fine, via the ECU and the installation is button tight. The truck has 6k on it and I had ran nothing but 87 octane until recently when I got the supercharger, thoughts?
