Hello all. I have a 99 Blazer with 190,000 miles. Still runs great. I've pulled good maintenance on it since I've owned it (since 2000). Anyways, the front differential has developed a leak. I don't know if it leaks completely out or not, but I'll fill it up, and then have a fairly descent puddle underneath for the next several days. It doesn't make any sounds, grinding, howling, etc. It still works great when I put it in 4wd. (I take it out on a gravel road once a month, and shift from 2 to 4wd, and Low range 4wd, just to keep things freed up). Anyways, my mechanic says it is an entailed project to tear into it and repair it. Don't really want to spend the money if I can help it. And it's probably not a task I want to tackle. Does anyone have any experience with these differentials? How hard is it to repair? And lastly, is there a good "stop leak" that I can use? One that anyone has had any luck with? Thank you all.
