Just picked up a '94 F-150. Has the 5 speed manual. Runs good and all and I want to change out all the fluids. The owners manual says to use Type F ATF. Is this info outdated, and if so, what would be a better choice for the truck? Type F is just such an ancient spec, that I have to believe there is something better. I believe the trans is manufactured by Mazda. Any input would be appreciated. Also, the trans looks to be leaking from what look to be rubber plugs. Is there an alternative to just putting in new rubber plugs?
