Originally Posted By: TurboJim
Originally Posted By: ZeeOSix
Three reasons I don't like an ecore filter design:
1) Open plastic cage that increased risk of media blow-out.
2) Dual function combo ADBV/bypass valve (reliable functionality questionable).
3) Non-metal end caps.
The open cage design is less restrictive for oil flow over a conventional metal center tube with it's small holes or louvers. I have seen conventional filters who's media had holes blown through the tiny center tube holes. In normal service this isn't going to happen of course. I think the nylon cage is the best design feature of the Ecore.
I wouldn't agree that the nylon cage is the best design feature, as it's just too wide open and doesn't provide enough media support for my taste, and the main reason the media can potentially blow through it.
As far as the open cage providing less flow restriction ... in theory yes, but I doubt you could hardly measure the difference in the test laboratory. The media itself contributes the largest percentage of restriction in a filter's overall/total restriction. When a PureOne can flow 12 GPM of hot oil and only have a total of 5 PSID pressure drop, then I'd say the conventional metal center tube with lots of small holes is flowing pretty well.
http://www.bobistheoilguy.com/forums/ubb...451#Post1619451
I agree with your point about the combo valve not being ideal.
But personally I like metal end caps because: 1) they don't distort thereby insuring the ABDV seals well around the center tube area, and 2) the pleats are glued in very securely insuring no oil leaks past the filtering media. Metal end caps really don't take up much real estate in the filter IMO.
