VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
31 registered members (CB900F2, BobFout, AurionX2, 4WD, bubbatime, 5 invisible), 685 guests, and 57 spiders.
Topics286,267
Posts4,905,529
Members67,589
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Rotella cured my Honda 400X #2370997
09/08/11 06:30 AM
09/08/11 06:30 AM
IL
04SE Offline OP
04SE  Offline OP
IL
So, my 2012 Honda 400X came with what I am 99% sure was a 10w30 factory fill of horse wizz. I ran it for 2.5 semi-hard hours before the gearbox began to "ker-chunk" up and down the gears. So, I picked up some Valvoline ATV 10w40 to maintain my (factory) warranty for cheap. Well, it made a big difference and I thought I had a keeper. However, after about 3 hours, it was horse wizz too. I was having difficulty getting neutral and reverse.
Wanting to protect my air cooled blast furnace of an engine, I put Rotella 15w40 in it and the gears are smooth as butter. Now I can get neutral with ease and reverse is a cinch to engage.
The 2012 400X strongly recommends 10w30 but allows 10w40 in "hot" weather. However, the previous model year allowed up to a 20w50. The internet theory is that Honda now recommends a 10w30 to keep "Kalifornya" happy.
My plan is Rotella 15w40 during the warmer months and Rotella 10w30 during the colder months. I know, Rotella 10w30 is not JASO MA rated. Screw it, if it breaks, I will build a 416 motor. Warranty be danged!
Life's little problems can be solved with a shovel and silence.
Re: Rotella cured my Honda 400X [Re: 04SE] #2371005
09/08/11 07:00 AM
09/08/11 07:00 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
If its exactly the same engine there maybe some truth to that.
Re: Rotella cured my Honda 400X [Re: 04SE] #2371070
09/08/11 08:36 AM
09/08/11 08:36 AM
Massachusetts
Zaedock Offline
Zaedock  Offline
Massachusetts
I would never run 10W30 in that engine. I have an '01 400EX with a slight bore and mods and run Castrol Syntec 20w50.
Smooth running / shifting no matter how hot. I think your Rotella 15W40 is a good choice though. I run Mobil 15w50 in my wife's Rancher.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Rotella cured my Honda 400X [Re: 04SE] #2371152
09/08/11 10:18 AM
09/08/11 10:18 AM
Ozark Mountains
callbay Offline
callbay  Offline
Ozark Mountains
I used to trust what was recomended in owners manuals. Since CAFE came along and 5-20 oil started to be recomended in the US while the companies would recomend much thicker oil for the same engines in other contries I stopped believing that the companies had the best thing for the engines in mind anymore. The manuals now are often writen for politcal reasons. Like recomending 5-20 for a tad better fuel milage or saying not to change the ATF at all. Yes I know that your engine will not blow up using thinner CAFE oil. But as a BITOG member I want to choose the oil I think is best for my engine not what the goverment thinks is best for their own reasons.
Re: Rotella cured my Honda 400X [Re: 04SE] #2383188
09/20/11 08:12 PM
09/20/11 08:12 PM
Canada
boraticus Offline
boraticus  Offline
Canada
Rotella 15W40 and Rotella 10W30 are both very durable oils more than capable of handling the demands of your engine. I use both in numerous machines from motorcycles/atvs to diesel generator engines. Never had an oil related issue. You've chosen very good oil. Carry on.
Re: Rotella cured my Honda 400X [Re: 04SE] #2385500
09/23/11 08:31 AM
09/23/11 08:31 AM
Mississippi
ddrumman2004 Offline
Mississippi
I have a 07 Rubicon with the Hondamatic tranny and Honda specs 10W-30 oil for this machine but I use Rotella 5W-40 synthetic and it runs and shifts just fine.
I use the Rotella in my son's 09 Recon and my Wife's 04 Yamaha Bruin 350....even in my Yamaha 650 motorcycle.
2018 Ford F 150 Extended Cab STX with 2.7 Ecoboost
2012 Mustang convertible V6 auto.
1993 Honda Golding trike
Re: Rotella cured my Honda 400X [Re: 04SE] #2391487
09/29/11 03:32 PM
09/29/11 03:32 PM
Michigan
MrRPM Offline
MrRPM  Offline
Michigan
is rotella safe for wet clutches found in your 400x?
motorcycles and ATVs using wet clutches need a specific oil so it does not harm the clutch
2001 Jeep Wrangler 4.0L, 5qts Quaker State DEFY 10w-30/1qt kendall GT-1 20w-50, FRAM XG8A (ultra)
Re: Rotella cured my Honda 400X [Re: MrRPM] #2391557
09/29/11 04:41 PM
09/29/11 04:41 PM
IL
04SE Offline OP
04SE  Offline OP
IL
Yes, Rotella Triple Protection 15w40 and Rotella T6 5w40 are both JASO MA rated.
Re: Rotella cured my Honda 400X [Re: 04SE] #2391675
09/29/11 07:10 PM
09/29/11 07:10 PM
Michigan
MrRPM Offline
MrRPM  Offline
Michigan
VERY interesting.......
I might start doing this.....
Re: Rotella cured my Honda 400X [Re: MrRPM] #2391710
09/29/11 07:59 PM
09/29/11 07:59 PM
IL
04SE Offline OP
04SE  Offline OP
IL
I recommend them both. They are low cost alternatives to OEM oils and boutique oils.
The thing that "harms" clutches is moly and I do not know if BITOG has established how much is too much for a clutch. It seems that some ATV or motorcycle specific oils have anywhere from 75 ppm to 100 ppm (or more) and some have zero.
Re: Rotella cured my Honda 400X [Re: 04SE] #2391754
09/29/11 08:37 PM
09/29/11 08:37 PM
Michigan
MrRPM Offline
MrRPM  Offline
Michigan
hmmm, well that is good to know.
I usually get Honda's GN4 for free from my fathers work and sometimes yamalube but if I ever come short and dont have enough for all the machines (6 ATVs, plus lawn mower and generator since i run gn4 is those too lol) ill use some t6 i normally have around from my jeep wrangler.
do you know if Mobil 1 Turbo diesel truck oil fits the same specs as t6 for atv usage?
Re: Rotella cured my Honda 400X [Re: MrRPM] #2392790
09/30/11 09:21 PM
09/30/11 09:21 PM
Indiana
OtisBlkR1 Offline
OtisBlkR1  Offline
Indiana
Id use the GN4 before the Yamalube.. lots of articles and testing have shown its not as stout as others.. Im not saying dont use it.. but if theres a better alternative...
Im also a little bias against Gn4, lost a motor once with it in the sump.. spun bearings...
06 Silverado 92,xxx Mobil 5-30
11 Honda Accord 38,xxx Mobil 1
06 Milan 69,000 Mobil 1
12 Ranger 800XP & 14 TRX 450R
Re: Rotella cured my Honda 400X [Re: 04SE] #2392927
10/01/11 03:17 AM
10/01/11 03:17 AM
Decatur AL USA
Gene K Offline
Gene K  Offline
Decatur AL USA
MoS2 (the type of Moly that causes clutch slip) is not currently used by any major US Blender in Motor Oil to the best of my knowledge.
MoTDC does not cause clutch slip and is the Moly used currently.
Rotella T6 contains MoTDC but as stated thats a non-issue.
Gene
2014 Mustang GT 5.0 SC - 675 bhp
ST Synthetic 10W30 / FL500S
2018 F150 4x4 3.5 EB
OEM Oil & Filter
2018 Lincoln MKX 3.7
OEM Oil & Filter
Re: Rotella cured my Honda 400X [Re: 04SE] #2393028
10/01/11 09:32 AM
10/01/11 09:32 AM
USA-Michigan
Mike_dup1 Offline
Mike_dup1  Offline
USA-Michigan
I use AMSOIL 0W-40 in my 1996 Honda Rincon since the day I brought it home, drove it around for about an hour, changed the oil to AMSOIL and in 3,000 miles it has never skipped a beat, shifts perfectly and the oil is changed once a year, average about 400-500 during summer and park in the winter (Nov to May). Been a great ATV, never spent a dime on repairs. Just put gas in it and go anywhere. Friend bought a Rolaris Ranger about the same time, has 1/2 miles I have and has spent thousands of $$ in repairs, parts just breaking from normal use.
2017 GMC Sierra Denali Ultimate CC 6.2L 4WD
2018 John Deere X738
2018 Polaris RZR S 900 EPS
2016 Polaris RZR 900 EPS
Re: Rotella cured my Honda 400X [Re: 04SE] #2393225
10/01/11 02:55 PM
10/01/11 02:55 PM
Michigan
MrRPM Offline
MrRPM  Offline
Michigan
thats Honda Vs. Polaris for you. Polaris is junk
sure they can be a good machine but in comparison to honda for reliability they are junk. even compared to the other Japanese companies im never a fan of polaris. when their machines are working they can be great machines...but its gonna break.
But i do gotta say some people have luck with polaris but in my experience i would never own one.
Page 1 of 3 1 2 3
