The front and rear calipers are sticking a bit in my car I'm thinking about rebuilding all four instead of getting rebuilt ones. Does anyone have experience using generic rebuild kits? Honda OEM is $15+ (piston boot, seal, pin boots, grease), whereas Autozone is $3 (piston boot and seal)+ $10 for grease. Big price difference when you do all four.
Btw, how often is the piston and bore damaged/corroded enough to be the main culprit. Both the calipers that are sticking are only doing so slightly.
Thanks.
Thanks.
