2018 chevy express passenger van
by Fitter30 - 04/04/20 04:01 PM
Twilight Zone
by 2015_PSD - 04/04/20 03:57 PM
Local dealership charges $15 for an oil change.....
by Harrington - 04/04/20 02:57 PM
Did harvest king change suppliers?
by Micahmcmeen - 04/04/20 02:30 PM
Switching back from High mileage to regular.
by Micahmcmeen - 04/04/20 02:28 PM
Changed the spark plugs on Subaru BRZ with pics
by Ded Mazai - 04/04/20 01:08 PM
Two filter sizes for Skyactiv 2.5?
by buster - 04/04/20 12:31 PM
Valvoline AFS Euro 0W-40 $25-4-10 Qts.
by Jackson_Slugger - 04/04/20 11:36 AM
pay cut at work
by marine65 - 04/04/20 11:17 AM
Asking For Advice- Lubricate Under Hot Water
by PGB1 - 04/04/20 11:05 AM
Castrol Magnatec 0W-20 2-4-$30
by Jackson_Slugger - 04/04/20 10:58 AM
Purolator One synthetic vs paper
by Duffyjr - 04/04/20 10:57 AM
RockAuto Discount Code
by RoadDukie - 04/04/20 10:53 AM
Grease fittings on drop links - is this a defect?
by wolfestone - 04/04/20 10:51 AM
How clean vinyl steering wheel?
by WobblyElvis - 04/04/20 10:49 AM
90s European Toyotas Coolant
by EWPE - 04/04/20 10:42 AM
Locker plants are swamped
by P10crew - 04/04/20 10:39 AM
New Jeep Rear Cargo Tray
by 2015_PSD - 04/04/20 10:30 AM
I'm getting fat.
by BeerCan - 04/04/20 10:26 AM
357sig, Garyv, PGB1, YoDaveO, Johnya25
71094 Registered Users
103 registered members (41Pack, 2015_PSD, 55hambone, 762fermeandyou, 01rangerxl, 928, 8 invisible), 2,326 guests, and 18 spiders.
Topics303,589
Posts5,237,888
Members71,094
BMW Dynamic Stability Control Problem #2368870 09/06/11 10:24 AM
E
exranger06 Offline OP
E
My mom has a 2005 BMW 330ci convertible with only 13k miles on it. The other day she said some light came on the dash. I took a look and it's the light for the Dynamic Stability Control (DSC). The light for the parking brake is also on. According to the owner's manual, the light should come on if you turn the DSC off via the button on the dash. Pressing the button doesn't do anything. So that means there's a malfunction in the system. The car drives fine and has no odd symptoms. Where should I begin looking for the cause of this problem? Can anyone tell me which code readers/scanners can read BMW-specific DSC codes? This is NOT something the average $100 code reader can do.
2006 Ford Ranger Sport
1992 Honda Accord EX
2013 Toyota Sienna XLE AWD
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: BMW Dynamic Stability Control Problem [Re: exranger06] #2368884 09/06/11 10:39 AM
W
Win Offline
W
Is it still on the original battery?
In my experience, some European cars can be sensitive to voltage drop during cranking and set oddball faults if voltage drops too low, when there is nothing really wrong with the car.
Might try disconnecting the battery, give it a good charge, and reboot the car.
09 Torrent 3.6 V6 M1 0/30
09 Solstice 2.4 I4 Fram 5/30
08 G8 3.6 V6 ST Syn 5/30
04 Xj8 4.2 V8 Hav 5/40
99 S-10 2.2 I4 RECOVERED
94 Xj12 6.0 V12
Re: BMW Dynamic Stability Control Problem [Re: exranger06] #2368891 09/06/11 10:47 AM
bdcardinal Online Content
Online Content
Check the battery, low voltage will do weird things. Also on some of the newer BMWs you have to have the PCM reprogrammed for a new battery due to the adaptive charging system.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: BMW Dynamic Stability Control Problem [Re: exranger06] #2368894 09/06/11 10:50 AM
scurvy Offline
Sounds like one of the ABS sensors might be malfunctioning. Also appears plenty of other E46 owners have the same issue:
http://forum.e46fanatics.com/showthread.php?t=697551
From what I've gleaned on that thread the brakes are wired in through the DSC system so she may just need a brake job.
You are entitled to your own opinion but not your own facts.
06 VW Golf TDI: Shell Rotella T6 5w40, HU726/2x, EaBP90
12 Mazda 5: Castrol Edge 0w20, FL910s
Re: BMW Dynamic Stability Control Problem [Re: exranger06] #2368915 09/06/11 11:09 AM
E
E
I had the battery disconnected and removed from the car all winter long. I reinstalled it in the spring and the car drove fine all summer long, no reprogramming needed. Like I said, the car has only 13k miles and a lot of that is highway, so I highly doubt the brakes are shot, but I can check them anyway.
Re: BMW Dynamic Stability Control Problem [Re: exranger06] #2368935 09/06/11 11:37 AM
E
E
Oh yeah, the ABS light is NOT on, only the DSC and (parking) BRAKE light.
Re: BMW Dynamic Stability Control Problem [Re: exranger06] #2369079 09/06/11 01:41 PM
A
antonmnster Offline
A
Is the BRAKE light yellow or red. Usually those two light only turn on when you disable the system by pressing the DSC switch; that combo is you turned it off. Did something get spilled on the switch?
2007 BMW 335i n54 218,000 miles, lubricated by whatever is on sale
Re: BMW Dynamic Stability Control Problem [Re: exranger06] #2369099 09/06/11 02:09 PM
E
E
I don't remember what color it was. Like I said, pressing the button doesn't make it turn off. Nothing spilled on the button, food and drinks are not allowed within 10 feet of this car lol. It is absolutely mint (and SHOULDN'T be having any problems...)
Re: BMW Dynamic Stability Control Problem [Re: exranger06] #2369339 09/06/11 06:31 PM
U
urchin Offline
U
I'd make sure the battery is in good condition and then disconnect it for a period of 30 minutes, after you disconnect it put the key in the ignition and turn to start a few times to drain the capitance out of the electrical system. Then after 30 minutes reinstall the known GOOD battery. See what happens, get back to us.
I never heard of the ECU needing a reflash when the battery is disconnected, I tend to doubt that is accurate.
I do know it IS true with European cars that consistently low voltage or even slightly unstable voltage may cause symptoms like you mention, my own car, a VW will have alarm issues when the battery is not functioning correctly that would make you think it was system related.
Re: BMW Dynamic Stability Control Problem [Re: exranger06] #2369379 09/06/11 07:14 PM
E
E
Did a little more research. It seems it could either be a battery issue like some have said, or it's probably a sensor for the DSC system (ABS sensor, steering angle sensor, etc), or maybe the DSC module. I found out that there are pretty much no code readers/scanners that can read BMW-specific DSC codes, pretty much except AutoEnginuity, which is really expensive and requires a laptop which I don't have, so screw that. So I can try checking out the battery and cleaning the ABS sensors and hope that fixes the problem. If it doesn't, I'm off to the dealer for a good ol' fashioned butt-raping. eek
Re: BMW Dynamic Stability Control Problem [Re: exranger06] #2369393 09/06/11 07:26 PM
A
artificialist Offline
A
Depending on the size of your city, you may have a place that is specialized in European cars only. You might be able to save money there.
2010 Lancer Ralliart Sportback
Re: BMW Dynamic Stability Control Problem [Re: exranger06] #2369433 09/06/11 07:52 PM
O
OVERKILL Offline
O
You need a Peake code reader.
Re: BMW Dynamic Stability Control Problem [Re: OVERKILL] #2369516 09/06/11 08:44 PM
E
E
I thought the Peake doesn't do DSC codes? I'll have to lok into it again
Re: BMW Dynamic Stability Control Problem [Re: exranger06] #2370086 09/07/11 12:27 PM
E
E
Just thought of something: If the problem had to do with dirt/debris on the ABS sensors, the ABS light should be on too right? Like I said before, the ABS light is NOT on. So I don't think I should even bother cleaning the sensors.
Re: BMW Dynamic Stability Control Problem [Re: exranger06] #2370108 09/07/11 12:40 PM
E
E
I just emailed Peake customer service. They said their readers do NOT read DSC codes.
