Originally Posted By: MetalSlug
Originally Posted By: Donald
What wears with respect to the timing chain on a GM 5.7L engine. I have one in a boat and one in a Suburban. Or do they just keep on going?
Depends on the year. If it came from a year where "silent" (that means "nylon") cam gears were in vogue, then the nylon wears down until the teeth break off the cam gear and the timing chain slides around the gear.
Years with all-metal chains are just like any other cam-in-block V8 with no tensioner- the chain gradually stretches and gets noiser and noisier. On the SBC in particular more than Ford and Mopars (although all will eventually do it), the floppy chain will begin to rub the timing cover until it grinds a hole in it and makes a nice big oil leak.
As the manufacturers have introduced more and more efficient engines that depend on very precise timing, variable valve timing, etc., even cam-in-block engines now usually have a slack-side chain tensioner and IT tends to become the early failure point. I've been told that the first couple of years of the new Hemi had some tensioner issues that would tend to show up around 100k miles. The Jeep 4.0 has a chain snubber, but it seems to last forever just like the rest of the engine.
Don't be quite so sure about the Jeep 4.0 engine lasting forever. Your year (2001) and a few other years has definite problems with piston skirt cracking and then possible total engine failure. In mine the wrist pin was not even attached to the piston when the oil pan was pulled. But yes, they are mostly bullet proof. My reman engine has almost 4K on it, wow!!
those having problem is the one that over rev the engine, over rev while off road, driving like having a v8, its 4.0l. its slow, drive it easy. I seen many wj on the road around here, every where I go, I seen at lest 5 wj.
That is true, however, there is another major weakness in some 4.0L Jeep engines:
Some cylinder heads are prone to cracking.
