The Engine has 234,000 miles but all else if fine minus oil consumption. Valve Stem seals (VSS) are the primary culprit on otherwise factory original engine.
Can the VSS be replaced with removing the valve covers and getting at them this way alone? Or, does the camshaft and other engine internals need to be messed with? (Translation super high labor costs and lift time)
Although it may be an apples and oranges comparison this poster was able to do it a Honda application ... which I may falsely assume is a DOHC application.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2327558#Post2327558
