Originally Posted By: ahoier
With MMO, the old addage "less is more" is really key
Just enough film to "coat" the innards of the fuel system, injectors, etc...
my typical dose is 3.25 oz. every fill up, using an old 2-cycle bottle
I just refill it every time I get home from the gas station. Honestly, if I could find a 2 or 3 oz. easy-dosing container, I'd use that instead. But the 3.25 every 10-11 gallon fill-up seems to be about right on-par.
Though, I noticed when I emptied that 3.25oz. of 2-cycle oil into my tank (wasn't gonna waste it! lol...) the car seemed to "stumble" a bit...note: it wasn't marked "TCW-3" but it did notate "Smokeless formula" with a notation about "Gas stabilizer added" or something....BUT, when I've added 4 oz. of MMO to a 10-11 gallon fill up, I didn't experience this "stumble" - so something tells me MMO is actually more "forgiving" than the 2-cycle/TCW-3
I also found MMO to be more forgiving than TCW3 if you OD it. I found my Aerostar seems to idle a bit better with TCW3 than MMO. I use TCW3 at 1 ounce/5 gallons of fuel from time to time in the Aerostar. You have to be careful on this site when you mention the word smoother, or if you mention increased mpg, you'll get called out. I don't long mpg anymore, so I can't comment. But I can tell you the 200,000 mile + Aerostar does idle smoother with TCW3 than MMO, confirmed by two butt meters. LOL. It might make for a better ring seal than MMO does. Now the disclaimer, JMO
