Originally Posted By: 2K5TSX
Originally Posted By: The_Eric
Originally Posted By: 229
You may have some tranny solenoids getting weak or need an PCU flash update. My 2008 had a factory update reprogramming.
Good suggestion with the re-flash.
Go back to the dealer and check for any re-flashes. If none are available, have them re-set the adaptives for the transmission and drive as you normally would after, so it can re-learn your driving habits.
I've done two battery resets since.. that resets the ECU and the transmission has to relearn shift points automatically as far as I know.
good point, not sure if Honda or Acura has updated AT software release after release DW1.
i did forgot to mention one point, while doing drain and fill with Maxlife, i notice the AT behave much better after 3rd drain and fill. the good feel with 1st drain and fill did not last very long. thanks!
