Car 2002 Acura RSX
Engine 2.0L, in-line 4, K20A3
Air Filter Comptech/Uni
Sump Size 5.6 qts
Dates in Service Feb '04 to Jul '04
Date.............01/13/04.......07/23/04
Lab..............Wearcheck......Wearcheck
Miles on Car.....37840..........47021
Miles on Oil......7040...........7001
Type of Oil.....M1 0w-20.....Synergyn 0w-20
Make-Up Oil......1/2 qt.........1/2 qt
Oil Filter.......Wix 51356........M1-110
Iron............6.3............6.3
Chromium.....0.2............0.9
Lead...........1.2............0.0
Copper........3.2............6.4
Tin.............0.4............0.5
Aluminum.....3.8............3.4
Nickel..........0.6............0.6
Silver..........0.0............0.0
Silicon.......12.0............7.4
Boron.......128.............93
Sodium........9.3............4.1
Potassium.....0.0............0.0
Magnesium....25.............29
Calcium......3032..........3436
Phosphorus..867..........1182
Zinc..........1031..........1486
Sulfer........2222..........3926
Molybdenum...75...........106
Fuel........... Water........... Glycol......... Visc @ 40....52.9........51.21
Visc @ 100....9.8.........9.51
VI.............173.........172
TAN...........3.32........3.79
Nitration.......---........95
I bought this oil before M1 0w-20 came on the market. I finally got around to trying it. Synergyn 0w-20 has ester, diester, and PAO basestocks. The lab flagged TAN as elevated. Wearcheck's cutoff for TAN in gasoline engines is 3.5. Gas mileage was the same with the two oils and oil consumption was slightly higher with the Synergyn than the M1.
Sump Size 5.6 qts
