Originally Posted By: Rtstrider
I was wanting to know what cons I might expect moving from a house to a mobile home. Any advice?
My mother in law had one that was new in 2002, she passed away in 2006 and we sold it in 2007 after the estate was settled. I did most of the maintenance for her.
From my observations, the build quality was far different and quite substandard to a stick built home. Everything seemed to be "cheap" and felt that way, even when they tried to use upscale materials. The door knobs on the closet doors were plastic, the insulation was marginal on a -20 day, and the exterior doors always felt like they'd pop open if you leaned on them hard enough. Nothing we replaced or repaired was standard home size-most things had to be purchased from a mobile home dealer.
The furnace, since it was centrally located and directly inside the main living area was loud when it ran, and in the winter it seemed to run all the time. Even though the central air unit was outside, the blower on the furnace still made running the AC loud during the summer. Servicing the furnace every year was a real treat since it was stuffed into a tiny closet, and everything was designed for a mobile home rather than a traditional home.
No matter how well tied down and supported it was, you could always feel the entire mobile home shake when the washer spun at high speed or became unbalanced.
I wasn't surprised when we sold it that it had depreciated significantly even though it was in good condition and in an upscale park. Mobile homes, at least in this area, simply don't hold their value like a traditional home.
That being said, it was a good choice for her final years. It was easy to clean, all on one level, and the park had a very nice rec building that the seniors liked. Taxes were cheap and utilities were reasonable. The park had some strict rules which kept the riff raff out.
