This is a special mix I started using at the drag strip, and on the track. I've always looked down on mixes, but tried this and was so shocked at the complete absence of wear metals irrespective of hours on the track, or miles on the odom. that I now run it exactly 50/50 in everything I own. The results are better than anything I have seen in all my years on this forum (or anywhere), or that i have ever personally returned. I currently use it in a Lotus 260 (300 wheel hp), C6 Z06 making 800 at the wheels, and an M3 making 550 at the wheels. also used in an EVO 9 making 400, and a 911 Turbo S that runs in the 9's in 100 F. All 5 cars are beat beyond description, absolutely terrorized both on and off track/strip, and all 3 engines return zero wear metals. I can't describe it, don't know, don't care, just wanted to put it out there for whatever it is worth. I've used every oil discussed on this forum and have never gleaned results like this mix. If you look at my history you will see I have tested everything under the sun. I have FINALLY found what I am looking for.... Thank God. Miracle formula, absolute miracle. I never expected perfect results in the M because it specs 10w-60, but even in that application at over 5k hard miles there was no metals present....
50/50 Mobi1 1 R (The new stuff, not the previous trash from a few years back peddled on Ebay and such, that stuff is [censored], not even good for oil hinges) and 50% AFE 0w-20 (but only the newest SN stuff gives the good result, the SM stuff does not make the magic), it is only the combination of these 2, in fact when I have used the Mobil 1 R 0w-50 the results are only ok.
I'm not sharing this for people to pontificate on, in fact, I no longer cruise the forum, I just want to share the fruits of a long expensive testing process, I do not read posts here, and will not reply to any questions.
this is what a precise 50/50 virgin sample looks like, anybody who uses this ratio WILL NOT be disappointed....
Iron 1
Moly 684
Pot 4
Boron 85
Sil 9
NA 2
Cal 1749
Mag 301
Phos 1136
Z 1251
63.2
11.12
F 395
Iron 1
Moly 684
Pot 4
Boron 85
Sil 9
NA 2
Cal 1749
Mag 301
Phos 1136
Z 1251
63.2
11.12
F 395
