My question centers on oil vaporization rates / oil burn consumption..
With my 1988 Porsche 944 non-turbo 8valve, I run Valvoline VR1 20W-50; this conventional racing/Dino oil Flash Point is 478F (248C)...
( I assume that is at 14.5psi? )
With current Virginia temps at 100F, what is the cylinder wall temperatures at say an average of 4k rpm?
For those using oils with lower Flash Points, does that equate to a greater oil burn rate?
Lastly, does 100F summer ambient vs. 25F winter temps really make any difference in these high temp equations?
( ie: running 15W-40 with an even lower FP)
As always, Thanks!
mikey
As always, Thanks!
mikey
