Topics284,588
Posts4,872,977
Members67,294
Most Online2,548 Feb 16th, 2019
Marvel Mystery Oil - My test of MMO & mpg
#2330638
07/28/11 03:59 PM
07/28/11 03:59 PM
Posts: 7,231 Mahzurrah!
KCJeep
OP
OP
Mahzurrah!
I'm now using Marvel Mystery Oil in the gas, carefully mixed at 4 oz per 10 gallons.
Now here's the test I conducted. About the time I got my Jeep 4 months ago I became interested in MMO due to good reviews here and elsewhere, so I started sporadically adding a little to gas now and then. Over time it became my perception that the fuel gauge went down faster without Marvel in the tank, so I started adding it consistently. I then decided I needed to do a more controlled test to see if I was wasting my money or not. Here's what I did.
With MMO added to the gas, I ran three complete tanks of fuel. My routine is very consistent and is a mixture of city and highway commute driving. I refueled at that exact same Phillips 66 station, used the exact same pump, and filled the tank on the lowest flow setting and removed the nozzle as soon as it clicked off the first time, no top offs. I considered this the best way I would be able to get a consistent fill without variation. It has been beastly hot this whole period so AC use has also been consistent, as well as tire pressures monitored. All calculations were done using the trip odometer and actual fuel used.
All three tanks with MMO netted 18.1 to 18.3 mpg. This is for my 04 Grand Cherokee 4.0 I-6 4wd.
I then refilled the exact same way and ran a tank without MMO. I got 15.96 mpg. Nothing changed that I know of than the MMO being excluded.
I didn't consider a single tank a conclusive sample so I ran another. That netted me 15.56 mpg. I wonder if a little MMO was still in the system the first time, as I dropped another .4 mpg on the second tank without it.
At that point I'd seen enough so I refilled and added MMO. Here's the real sweet part, a full 20 gallon fill of gas only takes 8 oz of MMO which costs a whopping $1.33. At + 2.5 mpg on 20 gallons thats another 50 miles, or $10.22 worth of gas in these parts, so even after deducting the MMO I pocket almost $9 a tank. I'll take that deal anyday!
Why does it work? I'm not really sure, MMO claims it improves combustion and lubricates the fuel system. My suspicion is that it's helping overcome that [censored] ethonal the govt is making them put in my gas. Note: MMO recommends 4 oz to 10 gallons and more is NOT better, in fact I plan to experiment with a little less on down the road.
I don't know if it will work for you but it is for me and I'm now introducing it into my other vehicles. No I don't work for MMO or anything like that, I'm just trying to help my fellow BITOG'ers save a buck. I know a lot of you are already using MMO, but those are my results as best as I can document them.
2018 VW Passat GT VR6 - 4k - Valvoline MST 5w40 - VW OEM filter 2012 KIA Sedona 95k - PP HM 10w30 2009 Ford Focus 133k - Supertech FS HM 5w30 2004 Jeep Grand Cherokee, gone but not forgotten.
Re: Marvel Mystery Oil - My test of MMO & mpg
[Re: KCJeep]
#2330641
07/28/11 04:04 PM
07/28/11 04:04 PM
Posts: 31,461 NY
demarpaint
NY
Nice report, several members have noticed increased mpg with MMO in the gas as well. We have a fair amount of people who hate MMO and will pick your test results apart,so be prepared. I use the product and think it is well worth it. Let us know how changing the MMO dose effects your mpg.
God Bless Our Troops
[Re: KCJeep]
#2330644
07/28/11 04:07 PM
07/28/11 04:07 PM
Posts: 3,172 Ohio
beast3300
Ohio
Excellent write up! I love MMO.
'03 Regal GS L67: PPUP 5w30/FU3980
'99 Grand Prix L36: R.I.P.
'07 LaCrosse L26: QS HM 5w30/TG3387A
ASE L1 MT
[Re: KCJeep]
#2330647
07/28/11 04:10 PM
07/28/11 04:10 PM
Posts: 3,397 Phoenix, AZ
panthermike
Phoenix, AZ
Nice job. You did everything right as far as filling up, etc. Nice results that you got.
An exact same route is really what you need to test mpg. I've tested various products and have kept detailed mpg. The only downside is that my job is a courier. As such, my "commute" is always variable. I have however found that MMO increases my mpg over 5,000 mile mpg records.
'15 Lexus RX350; ST 0w20/LG, 42K '10 F150 5.4; M1 0w40/LG, 99K '70 F100; Valvoline 15w40/LG
[Re: KCJeep]
#2330648
07/28/11 04:11 PM
07/28/11 04:11 PM
Posts: 19,528 Lake Forest, CA
HTSS_TR
Lake Forest, CA
I tried MMO in my '00 E430 twice, first it was 4oz per 10 gallons then 2oz per 10 gallons. Both times the engine felt sluggish in city and highway. I tried MMO because of positive posts like yours, MMO works well in some fuel systems and didn't work too well in some other fuel systems. But, I had better result using MMO in engine, the engine seems to run smoother.
'00 MB E430 '04 Honda S2000 '06 Volvo V70 '14 Honda Accord LX "Throwing food away is like stealing it from the poor and hungry" Pope Francis
[Re: KCJeep]
#2330654
07/28/11 04:18 PM
07/28/11 04:18 PM
Posts: 587 Michigan
Eosyn
Michigan
I'm doing the same thing since I found out about MMO on here. I'm keeping track of my MPG but not paying attention to details like you are (I do top-off my tank, fueling with lowest setting, etc) but I am keeping tire pressure constant. My 2 fill ups before finding out about MMO, I was getting 31.7 mpg and 33.7 mpg. ( I drive a 2002 Toyota Celica GT, 1.8L). the 2 times I did use MMO in the tank, I got a respectable 35.7 and 35.8 mpg. All of the above is driving 80% highway, 20% city. It seems to work for me also and I'm a believer too!
02 Toyota Celica GT: 198k, VML 5W30/Denso filter 05 Toyota Corolla LE: 149k, VML 5W30/Denso filter 15 Chevy Malibu LT: 46k, VML 0W20/Denso filter
[Re: KCJeep]
#2330665
07/28/11 04:36 PM
07/28/11 04:36 PM
KCJeep
OP
OP
Mahzurrah!
I also posted this on Jeepforum for my Jeep brothers, and here was a very interesting response posted there. Makes sense to me.
OP:
You are correct in stating that ethanol blends are an issue with today's fuels. Adding ethanol effectively strips any of the lubricating properties that fuels may have (remember leaded fuel? Yep, added for lubricity). Add to the fact that ethanol wicks moisture from the atomosphere and you can quickly see where this is going.
Unfortunately the issue is only going to get worse in the coming years, with the EPA recently clearing (IIRC) 2001 and newer vehicles for use with E15 blended fuels (15% Ethanol, 85% dino fuel). With this new blend, it is going to be increasingly important to use fuel driers in the winter and during long term storage of fuel, as water in the tank will be more prevalent.
[Re: KCJeep]
#2330681
07/28/11 04:52 PM
07/28/11 04:52 PM
Posts: 10,008 Upstate NY
sciphi
Upstate NY
I've seen the same effect on my Buick. I'll get about 2-3 mpg better on MMO than without. 29 mpg with MMO, 26 mpg without.
2013 Toyota RAV4 XLE 2012 Chevrolet Cruze Eco
[Re: KCJeep]
#2330701
07/28/11 05:17 PM
07/28/11 05:17 PM
Posts: 5,296 KC
badtlc
KC
Not to throw science into this discussion but that is a 17%+ increase in efficiency. You are obviously missing something in this experiment or purposely driving different to skew the numbers. There is no logical justification for that kind of increase.
2007 Ford Escape XLS 2.3L ATX, M1 AFE 0W20, Fram TG, 167k 2015 Chrysler T&C, 87k+, M1 AFE 0W20, Fram TG OF 2018 Forester Premium 3k+, Factory 0W20, Factory OF
[Re: KCJeep]
#2330703
07/28/11 05:19 PM
07/28/11 05:19 PM
Posts: 1,060 Ila Georgia,outside Athens Geo...
hounddog
Had a cold,loud lifter/rocker? tick in my 2006 vette at around 25k. Yes, nothing but Mobil 1 by about half of the OLM. Half a pint of MMO added to crankcase. In less then 500 miles of normal driving it went away. Changed oil/filter and still ok.
03 Dodge 3500 dually,08 Corvette convertible.09 Dodge 1500 5.7 2wd quad 3.92 gear,2010 Gran Marquis.
[Re: KCJeep]
#2330705
07/28/11 05:20 PM
07/28/11 05:20 PM
Posts: 3,498 Clermont, Florida
Jimmy9190
Clermont, Florida
Good job on the tests and tracking the results. I use MMO too, and I always get a consistent 1 to 2 more MPG with it than I do without it. Glad to know the MMO is working so well for you.
Jimmy9190 2013 Honda Civic LX Sedan QSUD 0W20 Fram PH7317
[Re: Jimmy9190]
#2330715
07/28/11 05:32 PM
07/28/11 05:32 PM
Posts: 263 VA, USA
chambers
VA, USA
I've been using MMO for awhile in my truck's gas and never saw any mpg improvement. I add it for it's properties as an upper cylinder and fuel system lube, cleaner, and stabilizer.
[Re: badtlc]
#2330716
07/28/11 05:32 PM
07/28/11 05:32 PM
Posts: 31,461 NY
demarpaint
NY
Not to throw science into this discussion but that is a 17%+ increase in efficiency. You are obviously missing something in this experiment or purposely driving different to skew the numbers. There is no logical justification for that kind of increase. All the people who had success with MMO must be wrong. LOL
