Here's a message I received from someone who uses this oil regularly:
Hi Mark,
Copper is an anti-oxidant, and RLI usually has around 100 ppm, so your 82ppm is fine, maybe even low (could be [censored]'s equip didn't detect it all or calibration is different than what I'm used to seeing, and they vary the ppm with viscosity & blend) and no, the copper is not abrasive in the way they're thinking. Most labs that don't know about RLI freak out a bit when they see the copper, as hardly anyone else uses it as an additive. The veg based bio-esters need a different chemistry to help stabilize them and this is one part of it.
Your engine looks like it's burning clean & doesn't appear to be abused or raced. The only item that's a bit high is silicon, which at 20k miles it shouldn't be sealers, so I'd make sure there's no air leaks in the PCV lines or air cleaner (unless you have dirt roads in your area). Maybe clean or replace the air filter element & make sure it's sealed when re-assembling.
Wear numbers all look very good to excellent (these LS7's always show a bit more iron than I'm used to compared to my German cars, but your bearing wear looks very low). I'd suspect running a 2cd oil change with this stuff will drop the numbers further as it flushes the rest of the old oil out of the engine & builds up a greater concentration of anti wear additives on the internal components. If the oil has been in for almost a year like the date on the UOA shows, I'd change it anyway, even though TBN is excellent.
