The CEL came on in my truck a few days ago. I did the key on-off trick and pulled these two codes:
P1128 - CLOSED LOOP FUELING NOT ACHIEVED - BANK 1
P1129 - CLOSED LOOP FUELING NOT ACHIEVED - BANK 2
Sometimes it will take 5-6 seconds of cranking for the truck to start. It happens pretty rarely. Also, driving home from work this morning there was a slight hesitation taking off from a stop sign. That is the first time I experienced that symptom. Otherwise, the truck runs fine.
There doesn't seem to be a whole lot of information on this on the internet. From what I could find the possible culprits are the MAP sensor, the 02 sensors, and a fuel delivery/pressure problem. I will check the fuel pressure first thing in the morning.
Any other ideas? It seems unlikely that both upstream 02 sensors would fail at exactly the same time. That would seem to point to the MAP given the fuel pressure checks out? I hate to start throwing parts at it.
Thanks in advance for the help!
