99' Ford Ranger 4.0 OHV Manual trans.
My original trans was going bad so I decided to get a rebuilt and put it in my self along with a new clutch and flywheel. This is the first time I have ever done something this involved on a car before so I wanted to give a shot and hopefully learn something.
Unfortunately, I seem to have made a newbie
mistake and something has gone wrong. The engine will not move at all, even with a long ratchet on the drive pulley. I though it was a battery or starter (replaced starter anyway since it was 13 years old) and all checks out after much work.
So in researching I find some posts on various forums about flywheel bolts being too long causing this, but on different cars. New flywheel is from NAPA, original was factory. Didn't check thickness of mounting area on new flywheel as I had never heard of this problem before.
I'm not familiar with what is behind the crank mounting area on the 4.0 that might cause binding.
Clutch seems to work OK and move. Master cylinder is rock solid when detached from trans (no air). Clutch pedal interlock is working fine (no starter action at all). Upon normal start, the starter engages (clack!) but goes no where with clutch depressed, lights dim.
Any help on this would be greatly appreciated!
