Originally Posted By: sciphi
Originally Posted By: Scorch
Do some searching on the topic or get a haynes/chilton manual and drop the pan, clean it, replace the filter and fill with what the owners manual states for ATF. Put 20k on it and drop the pan again, make sure it's nice and clean and refill again with the recommended ATF.
ATF is cheap, transmissions are not. Make sure you get new gaskets/ATF-RTV preferably from the dealer also.
The 4T65 doesn't require RTV on the gasket, or a new gasket. The OEM gasket is re-usable. It's also designed to seal with pressure, and not need RTV for a successful seal. I've removed the OEM gasket on my Buick several times over the years, and never had a problem getting it to re-seal once the transmission pan bolts were tightened just past hand-tight.
Definitely get the pan dropped and the filter changed. For ATF, any generic Dex/Merc will work since Dex-VI wasn't used yet, IIRC.
Thanks for the clarification, I just make the assumption sometimes that a new gasket is cheaper than restarting everything to fix a leak. And also my vehicle has no gasket, only mopar rtv, some genius thought that one up...
