Seeing the Lucas oil additive in auto stores on the display that shows as you turn the gears,the oil clings to them,does it really hold onto the surfaces better for start up or ?
Is it really good for added protection like the rest of the "additives" are? Additives better for higher miles or any like i have about 36,000 miles on my '05 impala 3.4 v/6.
Thinking about going with an additive to help the engine on start up so it doesn't have to be dry,so there's some sort of lube to help out.
Worth it or not...i know...that depends on the owner.
Normally i use castrol,quaker state and now i have shell oil and only use fram oil filters.
