With 8 days left till my registration expires, California finally decided to send me my documentation for rego renewal. It is also 30$ more this year than last, IIRC.
My last test 2 years ago, I was running a bit high on the hydrocarbons, but still passed. They are supposed to check the timing, but when the tech did not see a battery in my engine compartment, he just went back to the computer and typed in 10 btdc, what it is supposed to be. I later checked it and found it was at 18 btdc so it is a good thing my engine battery quit and I was using my under floor house batteries as my engine battery otherwise I would have failed the test and wasted 65$.
Anyway, I am theorizing the high HC numbers were due in part to the advanced timing, and an out of whack Coolant Temp sensor which I have since replaced(along with the whole cooling system)
My one friend says that I should go to the test with 91 or higher octane fuel in my tank. I always buy 87 as I never get any pinging. Will higher octane lower my CO/NO/HC numbers?
I've also recently tried some MMO in my gas for the first time with the last 8 gallons. The engine seems a little rev happier in neutral, but perhaps less power too. I kinda guestimated 4 ounces of MMO and the amount of fuel in the tank at about 10 gallons but perhaps I used too much.
Will having MMO in the tank during the smog test negatively or positively affect the Smog numbers?
I have throttle body fuel injection, 25 K miles on a magnaflow catcon, and 35k miles on the rebuilt 318 and really would like to pass this test with flying colors.
Thanks.
Thanks.
