Originally Posted By: NHHEMI
There are quite a few issues with these trannies that are pretty common. Obviously with proper care and easy driving you should be ok mechanically overall BUT this tranny is not bullet proof even if you take perfect care of it. I am not saying they all are horrid or anything. Just pointing out they have issues and you need to take good care of them or you greatly increase your odds of a failure.
Here are some common issues with the tranny in question. Do a search for 4T65E transmission problems and look for yourself...
Shift solenoid failure
Harsh shifts
Fluid leaks from the upper vent
Loss of 4th gear and/or 3rd-4th issues
Whining and grinding noises
Input clutch piston failure
Yeah, these units can last a long time... but they're far from perfect. From what I've read- anecdotally- it seems that problems with these transmissions are more common with heavier vehicles & more powerful engines.
I have a 4t65e in my '01 Lumina with 230,000 miles on it, and it shifts perfectly. Probably helps that the 3100 engine doesn't have enough torque to pull the hat off your head. The only issues I've had with the transmission are the following:
When I bought the car at 159,000 miles, it had a small oil leak at the driver's side axle shaft seal. I replace the seal and it was fine for a year or two; then it started leaking again. I don't plan to change the seal again unless/until it starts leaving drips and/or puddles. So far it's just making a small mess on the side of the transmission. I don't expect to have to replace it again.
Also I changed the ATF to Dexron VI a few years ago- around 175K miles. This made the full-throttle 1-2 shift do a nasty slip & grab thing. I just quit using full throttle for several thousand miles until I got around to doing a complete flush with Transynd. That solved the problem- the full throttle 1-2 shift is still softer than I'd prefer, but perfectly normal. So for whatever reason MY 4t65e does not like Dexron VI, but works fine with cheap Dexron III or with Transynd (synthetic Dexron III). YMMV.
I installed a transmission cooler and a spin-on filter base when I bought the vehicle maybe 5.5 years/70,000 miles ago. I don't know how much difference it really makes, but it makes me feel better.
