Originally Posted By: chubbs1
Originally Posted By: HTSS_TR
Originally Posted By: toofastgtp
I have been feeding my 95' Lexus ES300 PYB 5w30 since i got the car about a year ago (first oil change was Penz plat)
My question is would a different oil help with MPG increase? or should i just keep feeding her PYB? (136k on clock)
95% of all my driving is city and stop and go. Out of a tank i can see anywhere from 16-18mpg.
Plugs, PCV, and fuel filter was done about a year ago. Air filter about 6 months ago.
If your daily trips are less than 10 miles, the oil almost never get to operating temperature of 200-210F, then you could use xW20. xW20 at 180-190F is as thick as xW30 at 200-210F and much thicker than xW30 at 220-230F.
HTSS-TR...If xw20 is the same Vis. at 180-190F as xw30 at 200-210F than what benefit would it be to use 5w20 for short tripping?
Not to mention I am confused that a 20wgt oil would be MUCH thicker than a 30wgt at 230F. Can you explain? I am now lost.
If your daily trips are more than 20-30 miles, then at the end of the drives the oil temperature of xW30 could be around 200-210F. If the trips are less than 10 miles then the temp could be as low as 170-180F or even lower. At that low temp the oil much thicker than at 200-210F. If you use xW20 for short trips, then at 170-180F it is much thinner than xW30 but still thicker than xW30 at longer drives. Ideally, you want an oil that is as thin as possible from starting your engine until it reach normal operating temperature, and as thick as needed at operating temperature.
Using
http://www.widman.biz/English/Calculators/Graph.html you will be able to see the oil thickness of various grades at various temp (in C). Then you'll see that for short drives you like to use as thin an oil as possible.
