I'm getting to the point in my tractor restoration that I need to purchase more grease.
Two sets of bearings are in the fan shaft and in the clutch drum. Both of these require disassembly to re-grease and is called for annually. This tractor will probably not see the equivalent of a year's farming in the next 70 years of it's life. I'd like to be able to go several years on this service.
A bit of searching seems to indicate that the polyurea greases don't dry out as much as the soap based greases, therefore may be a better candidate for long term use. Am I correct in this assumption?
This John Deere grease is readily available and reasonably priced. This looks like it will nicely cover all uses on this tractor.
Multi-Purpose SD Polyurea Grease (TY6341, TY24421, TY24422, TY26982, CXTY24419)
Applications
Ideal in rolling-contact applications
15 to 350°F (-26 to 177°C)
For high-temperature, extreme-pressure conditions
Used for initial lubrication at the factory in U-joints and axle bearings
For excellent protection in corrosive and wet conditions
Compatible with most other types of grease
Excellent for all-purpose applications, especially those requiring a severe-duty grease
Our best multi-purpose grease
Service rating
Equipment manufacturers' extended service intervals
NLGI grade 2
GC-LB
Test analysis
Penetration @ 77°F (25°C), 60 strokes 275-295 mm/10
Dropping point, degrees F 500°F
Timken OK load, minimum 45 lb. (20.4 kg)
Water washout @ 175°F (79.5°C), loss 2%
Oxidation pressure drop @ 100 hours, maximum 10 psi
Ed
Applications
Service rating
NLGI grade 2
GC-LB
Test analysis
Ed
