CATERHAM
Thread starter
Since the HTHS vis spec' correlates so well with the operating viscosity in an engine at typical operating temps and the KV100 spec' doesn't, the following guide might be useful to judge how thick or thin an oil actually will be in an engine:
HTHS Vis' Value
2.60 cP ...........a light 20wt oil
2.70 cP ...........a mid-grade 20wt oil
2.80 cP ...........a heavy (thick) 20wt oil
2.91 - 3.10 cP ... a light 30wt oil
3.20 - 3.40 cP ... a mid-grade 30wt oil
3.50 - 3.60 cP ... a heavy 30wt oil
3.70 - 3.80 cP ... a light 40wt oil
3.90 - 4.10 cP ... a mid-grade 40wt oil
4.11 - 4.20 cP ... a heavy 40wt oil
4.21 - 4.40 cP ... a light 50wt oil
4.50 - 4.70 cP ... a mid-grade 50wt oil
4.80 - 5.20 cP ... a heavy 50wt oil
5.3 .........cP entry point to a 60wt oil
For any given HTHS vis' you will have a range of possible KV100 values but it is the HTHS vis' that correlates with operating viscosity.
HTHS Vis' Value
