Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Joey Logano and the 2019 Mustang
by Malo83. 12/13/18 02:40 PM
BMW LL01FE Spec
by The Critic. 12/13/18 02:03 PM
I Tried and Failed to Not Buy a New Car
by badtlc. 12/13/18 01:49 PM
OEM Brand Coolant by Rocochem
by NumbersGuy. 12/13/18 01:15 PM
Motomaster Dexron Vi Fully Synthetic
by Gannet167. 12/13/18 12:55 PM
Hacked
by Smoky14. 12/13/18 12:41 PM
Scanning for U codes.
by LeakySeals. 12/13/18 12:23 PM
Food photography trickery
by nthach. 12/13/18 11:29 AM
oil for 2.5 2013 vw passat?
by jstert. 12/13/18 09:47 AM
Scotty Kilmer Parody
by oilpsi2high. 12/13/18 09:41 AM
ID this old tool
by John_Conrad. 12/13/18 09:30 AM
Weak New CR2032/remote start + fob batteries
by redhat. 12/13/18 09:23 AM
WondrousBread, slickoo9, turntable_life, Poles19, HinaMach
66669 Registered Users
110 registered members (aquariuscsm, 28oz, Ag76, andyd, 2K2AcuraTL, 10 invisible), 1,937 guests, and 36 spiders.
Topics295,032
Posts4,926,413
Members66,669
Most Online2,553
Oct 27th, 2018
How to compare mowers rated in HP vs ft-lb #2274273
05/29/11 11:36 PM
05/29/11 11:36 PM
Toronto ON, Canada
smayer97 Offline OP
smayer97  Offline OP
Toronto ON, Canada
In trying to make a buying decision for a new lawn mower I got stumped when I finally realized (it took me 2-3 days) that the rating system had changed.
How can you compare older mowers (before mid-2007), that are rated in HP, to the newer ones (mid-2007 onward), that are rated in ft-lbs of torque, or even worse only give you size in cc's? How do you make a decision on what to buy?
I have decided to summarize the pertinent information I gathered from my research in a very concise way so any consumer can have a starting point for comparison in a SIMPLE way.
First, if you have an "older mower" you need to know its effective or "real" HP based on its operating RPM.
Example:
Want to know the actual HP of your older mower?
Older mower is 6 HP. Multiply by 0.85 = 5.1 HP ("Real" HP)
0.85 = 3060/3600 (to convert from tested RPM to actual RPM)
Too hard to calculate in your head on the spot?
Try multiplying by 0.8, then add 0.3 to your answer. This is a close approximation.
Want to know the torque of your older mower?
First, make sure you know the "real" HP of your motor (as above).
Then use the "real" HP as follows:
Older mower is 5.1 HP. Divide by 0.6 (or multiply by 10 and divide by 6) = 8.5 ft-lb.
Want to know the HP of a newer mower?
Newer mower is 7 ft-lb torque. Multiply by 0.6 = 4.2 HP
Remember, this is only to give you simple way to start to be able to do a comparison but it is based on several ASSUMPTIONS. They are not important, just to keep it SIMPLE. Even the "real" HP is NOT the real HP. But that is too much detail to cover here.
If you can AVOID IT, don't bother trying to compare size or displacement of a motor shown in cc's for the simple example that even B & S has the same 190 cc motor that is sold as a 6.75 ft-lb torque model all the way to an 8.5 ft-lb torque model. Unfortunately, in many cases that is all the info that is supplied. Then your only fallback is the following:
Want to know what the HP is for a certain size engine? Use the old rule of thumb:
Engine is 190 cc's. Divide by 28 = 6.8 HP (this is the "rated" HP. Now multiply by 0.85 = 5.8 "real" HP. This is a VERY ROUGH estimate.
Too hard to calculate in your head? Try dividing by 30. (I think this is a slightly better estimate anyway.)
I hope this helps someone. It sure did for me when I had to buy a new one yesterday. (I registered on this forum just so I could share this.)
Want to know more about WHY the rating system changed? Go to these 3 links. Each contains slightly different info to give you a more complete picture:
http://www.washingtonpost.com/wp-dyn/content/article/2008/02/15/AR2008021501732.html
http://forums2.gardenweb.com/forums/load/tractor/msg0215391823783.html?26427
http://www.inspectionnews.net/home_inspe...-vs-ft-lbs.html
Want to know more about the CALCULATIONS? Go to this link for a good explanation:
http://www.revsearch.com/dynamometer/torque_vs_horsepower.html
Re: How to compare mowers rated in HP vs ft-lb [Re: smayer97] #2274298
05/30/11 01:34 AM
05/30/11 01:34 AM
Orange County, CA
dtt004 Offline
dtt004  Offline
Orange County, CA
Hi.
Useful information. However, there is no way to convert torque to horsepower. They are different things. Horsepower is a unit of power. N.m is a unit of torque. In physics, they are two totally different things.
Nevertheless, useful.
Technical Design Engineer
1991 Toyota MR2 Turbo
1993 Mazda RX-7 Turbo
1996 Toyota Tacoma V6 4x4
2005 Acura NSX
2008 Lotus Elise
2004 Kawasaki Ninja ZX-10R
Re: How to compare mowers rated in HP vs ft-lb [Re: smayer97] #2274319
05/30/11 05:19 AM
05/30/11 05:19 AM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Here's a link that will help:
http://www.calculatoredge.com/new/horsepower.htm
As you can see, you can convert from hp to torque and torque to hp.
Thick vs Thin test: 15k / 43k miles complete
Re: How to compare mowers rated in HP vs ft-lb [Re: smayer97] #2274332
05/30/11 06:05 AM
05/30/11 06:05 AM
East of IGO
Steve S Offline
Steve S  Offline
East of IGO
It is just a number. There are only a few engines available on push type mowers.
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
Re: How to compare mowers rated in HP vs ft-lb [Re: smayer97] #2274340
05/30/11 06:21 AM
05/30/11 06:21 AM
Retired | Wausau, WI
Johnny Offline
Johnny  Offline
welcome to BITOG
Thanks for the effort, but don't stop there. What mower did you buy and what oil are you going to use in it?
Re: How to compare mowers rated in HP vs ft-lb [Re: dtt004] #2274353
05/30/11 06:34 AM
05/30/11 06:34 AM
OH
fdcg27 Offline
fdcg27  Offline
OH
They are two different things, but if you know one, and the RPMs at which it was measured, you can easily calculate the other.
Torque by itself is a measure of twisting force, while horsepower is a measure of work performed, whether cutting the grass or cruising the interstate.
OTOH, SteveS is probably right.
Unless you place really unusual demands on a mower, any engine offered will work.
Also, deck and blade design play a big role in how well a mower will cut.
Finally, without regard to output, an old two stroke Lawnboy remains the ultimate mower for getting a clean cut in heavy grass, in my personal experience.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: How to compare mowers rated in HP vs ft-lb [Re: smayer97] #2274487
05/30/11 10:05 AM
05/30/11 10:05 AM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
Seems simpler to just get the highest rated (torque) engine you can find.
Without a parts list, it's difficult to know what (or if) specific parts might be different between two different rated engines on the same block.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: How to compare mowers rated in HP vs ft-lb [Re: dtt004] #2274512
05/30/11 10:29 AM
05/30/11 10:29 AM
Pennsylvania
Slick17601 Offline
Slick17601  Offline
Pennsylvania
Originally Posted By: dtt004
Hi.
Of course there is. A dyno measures torque which is converted to horsepower with a simple formula.
2018 Ram Bighorn 5.7
2008 Toyota Sienna 3.5
Re: How to compare mowers rated in HP vs ft-lb [Re: smayer97] #2275307
05/31/11 09:53 AM
05/31/11 09:53 AM
Southeast
meep Offline
meep  Offline
Southeast
well, if that torque number by itself is at the running rpm, it will be a good comparison for a given blade size. of course, a smaller mower can spin at a slightly higher rpm.
i suspect OHV vs flathead throws a big chink in the displace-to-HP conversion, as the flatheads are not as efficient for a given displacement.
Good info, welcome to bitog.
M
2018 F150
2015 crv (wifey!)
Re: How to compare mowers rated in HP vs ft-lb [Re: meep] #2275571
05/31/11 02:25 PM
05/31/11 02:25 PM
Top of Virginia
Hokiefyd Offline
Hokiefyd  Offline
Top of Virginia
It does. I did these charts YEARS ago, but there's still at least some validity to them.
http://www.jnjhome.net/ope/engines.htm
The flathead engines had the worst displacement-to-power ratio, at the worst displacement-to-torque ratio. Essentially, to get the same power as many OHV designs, they had to have a larger displacement (and likely used more fuel).
On the flip side, they were typically (and predictably) lighter for a given power or torque produced.
You can download the Excel file to see the raw data and the graphs.
Re: How to compare mowers rated in HP vs ft-lb [Re: dtt004] #2275622
05/31/11 03:24 PM
05/31/11 03:24 PM
United States
maineiac Offline
maineiac  Offline
United States
Hi.
This is a common misconception. Torque and horsepower ARE directly related and one is easily calculated from the other if you know the RPM at which the torque or horsepower value is measured:
Calculating Braking Torque:
Full-load motor torque is calculated to determine the required braking torque of a motor.
To Determine braking torque of a motor, apply this formula:
T = 5252 x HP
rpm
T = full-load motor torque (in lb-ft)
5252 = constant (33,000 divided by 3.14 x 2 = 5252)
HP = motor horsepower
rpm = speed of motor shaft
Example: What is the braking torque of a 60 HP, 240V motor rotating at 1725 rpm?
T = 5252 x HP
rpm
T = 5252 x 60
1725
T = 315,120
1725
T = 182.7 lb-ft
Re: How to compare mowers rated in HP vs ft-lb [Re: smayer97] #2276262
06/01/11 10:34 AM
06/01/11 10:34 AM
NorthEast
Vikas Offline
Vikas  Offline
NorthEast
What is the origin of 33000 in the above explanation? I am sure I used to know that in the past :-(
- Vikas
Re: How to compare mowers rated in HP vs ft-lb [Re: smayer97] #2276289
06/01/11 11:26 AM
06/01/11 11:26 AM
Rochester, NY
NateDN10 Offline
NateDN10  Offline
Rochester, NY
33000 foot-pounds of work per minute = 1 horsepower
2016 Mazda3 - 20,000 mi.
2011 Toyota Sienna - 100,000 mi.
Re: How to compare mowers rated in HP vs ft-lb [Re: smayer97] #2276404
06/01/11 02:05 PM
06/01/11 02:05 PM
NorthEast
Vikas Offline
Vikas  Offline
NorthEast
For some reason, I thought horsepower would be defined to be some "non-metric" number i.e. 28288 ft-lb of work per minute :-)
Re: How to compare mowers rated in HP vs ft-lb [Re: smayer97] #2285582
06/11/11 02:14 PM
06/11/11 02:14 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
It's based on one horse pulling a 1000 pound weight up a well, which is 33 feet deep, in one minute. 33000ft-lb = 1 HP
I read the story years ago in a history book; tried to locate the story online but couldn't locate it.
