What is better for my trucks suspension and linkage: Schaeffer's 221, 238, or 274 grease? I like the idea or extra moly in the 221 and 238, but I don't know if I need an "extra tackifier" that is in 238. The 274 seems to be better at colder temps. I have been in temps that go below 0*F (-18*C), so the 274 looks better. I like the idea of having an Aluminum Complex, rather than in inferiority inferior complex.
I am currently using Valvoline DuraBlend Moly Grease. Specs below.
NLGI Grade - 2
Soap Base - Lithium Complex
Color - Blue
ASTM Worked Penetration @ - 77°F 275
ASTM Dropping Point, °F - 545
Kinematic Vis @ 40° C, cSt - 129.5
Kinematic Vis @ 100° C, cSt - 14.5
Viscosity Index - (110)
Pour Point °C - (-18)
Timken OK Load, lbs min - 50
NLGI Grade - 2
Color - Blue
