Originally Posted By: 45ACP
Originally Posted By: qwikrex3794
So I was doing the oil change on my 370z using Nissan Ester oil, and a tiny flake of the aluminum oil bottle seal (about the diameter of a pinhead)fell into the the oil filler tube as I was filling up. Should I be worried?
No. Still shouldnt have let it drop in there, though.
It will not affect anything, the plastic will dissolve and its not like its a big major piece that can act as a foreign object. Same way with if a leaf or some other weird thing were to blow into fill hole, it will get in fliter and burn/evaporate into oblivion, dirtying up the oil a wee bit but its fine.
It is aluminum, not plastic. Why make up plastic??
Besides, the plastic would NOT dissolve or melt - that is nonsense.
There is nothing we can do about this except drive the car normally. Can it affect anything? Maybe. It may stick on the pickup screen, or smash/smear out in the pump, or end up in the filter.
