New Way To Wash A Car
by buster - 11/12/19 07:52 PM
Sealed vs open bearings. What's better?
by motor_oil_madman - 11/12/19 07:51 PM
Wix WL10290XP CUT OPEN GM 22psi
by LotI - 11/12/19 07:04 PM
Do high beams make you angry?
by 1978elcamino - 11/12/19 06:46 PM
VALVOLINE V0-148 CUT OPEN
by 53' Stude - 11/12/19 06:38 PM
VW Jetta oil filter CUT OPEN
by 53' Stude - 11/12/19 06:31 PM
Turtle Wax Seal & Shine On Top of Ice or Vice-Versa ?
by Dwight_Frye - 11/12/19 06:10 PM
Timing Cover Leak in Toyota/Lexus
by Gebo - 11/12/19 05:10 PM
Anyone running only Malwarebytes for security
by Donald - 11/12/19 05:07 PM
104+ Fuel Injector Pro ?
by ChrisD46 - 11/12/19 04:55 PM
Mobil 1 FS 0w40 vs Castrol 0w40
by Ndx - 11/12/19 04:14 PM
How often to drive a second car.
by SouthDakotaDad - 11/12/19 03:48 PM
Manufacturers, Bypasses & Large Sumps
by ad244 - 11/12/19 03:23 PM
Samsung DeX for PC
by dogememe - 11/12/19 03:19 PM
2008 Acura TL Timing Belt/Component Kit
by BAJA_05 - 11/12/19 02:06 PM
Installing decals and emblems in cold weather
by atikovi - 11/12/19 01:39 PM
Skyactiv 20,000 mile OCI with Oil Analysis
by thegameq - 11/12/19 01:23 PM
Hombre909, DeLong, Scuder, Jasonrmcc, Capacc
69840 Registered Users
121 registered members (92saturnsl2, 53' Stude, 69GTX, AC1DD, 1978elcamino, 18 invisible), 2,092 guests, and 22 spiders.
Topics297,334
Posts5,113,251
Members69,840
Most Online3,589
Nov 2nd, 2019
Page 30 of 30 1 29 30
Re: post your latest differential fluid change [Re: electrolover] #5208720 09/09/19 06:36 PM
Sam_Julier Online Content
Online Content
1993 Volvo 240 wagon (Dana 30)
Out: Phillips 66 85W-140
In: Valvoline HD 80W-90
Differential was rebuilt. Shop fills with 85W-140 which is too heavy for this unit.
2013 Toyota Avalon Hybrid PPHM 0W20, 70k
1993 Volvo 245 T5 10W30, 157k
1993 Volvo 244 T5 10W30, 169k
Re: post your latest differential fluid change [Re: electrolover] #5211160 09/12/19 05:35 PM
L
Lowflyer Offline
L
07 Audi S3 8P (Stage2-). Haldex-4WD with (separate) angle gear and diff
Out: 50:50 Castrol Syntrax 75W-90:75W-140
In: 50:50 Amsoil SevereGear 75W-90:75W-110
Changing each 45.000 miles. This week, with ~177.000 miles.
Re: post your latest differential fluid change [Re: electrolover] #5236224 10/10/19 05:53 PM
R
Red91 Offline
R
02 Chevy Blazer
Rear diff
Out: unknown
In: Napa 80/90
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: post your latest differential fluid change [Re: electrolover] #5241867 10/16/19 09:46 PM
B
BlakeB Offline
B
2010 Tacoma DCSB (1gr-fe), 42,909 miles
Rear Differential:
Out: factory fill 75w85
In: Starfire full synthetic 75w90
Front Differential:
Out: Factory Fill 75w85
In: Starfire 80w90
The factory fill in the front diff was in really bad shape so I refilled it with some cheap 80w90, I will change it out again with synthetic 75w90 at the next oil change.
Transfer Case:
Out: Factory fill 75w90
In: Amsoil 75w90 (GL-4)
The rear differential and transfer case fluids were in great shape (looked almost new with a minimal amount of fuzz on the rear diff magnet, it did have an odd sliver of metal stuck to it but being the factory fill with close to 10 years of use on it I’m not too worried about it.
DF11E0C7-6B74-470D-A9F6-D553CEE01F75.png8C6E209D-1F56-4220-8452-D5F5BF124945.png352C8EE3-839F-4920-A1FA-8FCCE2BFE394.png9B63C5E6-97EE-4C50-B3AD-BAE6AE6D4D3B.png
Re: post your latest differential fluid change [Re: electrolover] #5242406 10/17/19 12:34 PM
R
Red91 Offline
R
90 GMC K1500
Locker rear diff
Out: unknown
In: 75/25 mix Napa 80/90 and shell spirax 80/90, motorcraft xl-3 friction modifier
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: post your latest differential fluid change [Re: electrolover] #5244885 10/20/19 10:46 AM
K
kstanf150 Online Content
Online Content
K
Out FF and cover
In Shell Spirax 75/140 and a new diff cover with drain plug
Re: post your latest differential fluid change [Re: electrolover] #5245089 10/20/19 01:43 PM
Online Content
1993 Volvo 240 Wagon (Dana 30)
Out: Castrol Axle 80W90 GL-5
In: Same
Break in after differential rebuild seems to be complete. No metal on the magnetic drain plug.
Re: post your latest differential fluid change [Re: electrolover] #5250055 10/25/19 05:56 PM
I
irv Offline
I
Finally got around to doing my rear diff fluid change on my 13 Ram Hemi QC 4x4 today.
It is a LSD with 3.55 gear ratio.
Out went the factory fill at 79,000 km's (49,000 miles) and in went Pennzoil 75W-140 syn with the FCA friction modifier.
The gear oil that came out was quite dark but I have seen worse. Not a lot of silver/streaking but I was also surprised with the amount of foam/bubbles in it? I did a quick 5-7 mile drive before doing it and drained it within 5 minutes after arriving home. Is this normal to see bubbles/foaming? Not a lot but enough to notice it easily.
Hopefully tomorrow, weather and time permitting, I'll get around to doing the front?
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: post your latest differential fluid change [Re: electrolover] #5250271 10/25/19 11:15 PM
2
2strokeNorthstar Offline
2
01 F150 4x4 LSD. Out synpower 75w140, new diff cover and 75w140 back in. Used The Right Stuff for sealant. No additives and not needed.
2001 F150 5.4L
2013 Nissan Juke Nismo
2000 Honda S2000
1998 BMW 328i
Re: post your latest differential fluid change [Re: electrolover] #5252342 10/28/19 05:38 PM
R
Red91 Offline
R
94 Lincoln Town car
Open diff
Out: unknown
In: Napa 80/90
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: post your latest differential fluid change [Re: electrolover] #5252427 10/28/19 06:57 PM
E
edyvw Offline
E
2015 Toyota Sienna 64,000 miles
Transfer case and rear diff.
Out: Toyota 75W85 GL-5
In: Redline 75W85 GL-5
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: post your latest differential fluid change [Re: electrolover] #5252468 10/28/19 07:33 PM
O
Oey12 Offline
O
2017 Toyota 4Runner
41711 miles
Front/Rear Diffs
Out: Toyota Factory 75W85
In: Amsoil Severe Gear 75W90
Those Amsoil EZ bags makes this job so much easier...
Re: post your latest differential fluid change [Re: Oey12] #5252551 10/28/19 09:02 PM
B
BlakeB Offline
B
Originally Posted by Oey12
2017 Toyota 4Runner
41711 miles
Front/Rear Diffs
How did the front diff fluid look? I’m getting ready to do a 2016 4Runner with about 25k on it. On our Tacoma’s the first front diff fluid change has always looked pretty rough. You can see the 2010 Tacoma front diff fluid I changed at just shy of 43k in a post above.
Re: post your latest differential fluid change [Re: electrolover] #5253126 10/29/19 01:11 PM
R
Red91 Offline
R
04 Chevy Tahoe
Front and rear diffs, transfer case
Front diff
Out: grey crap
In: Mobil 1 75/90
Rear diff
Out: unknown
In: Mobil 1 75/90
Transfer case
Out: looked like transmission fluid
In: acdelco auto trak II
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
