AME 37330 Hub Cleaner for Impact Wrench
by The Critic - 11/18/19 01:54 AM
Plastic bag vs Car
by The Critic - 11/18/19 01:50 AM
Fram XG7317 20k miles cut open
by dbeau - 11/17/19 09:46 PM
2021 Ford Mach-E Electric SUV
by KeithS_NW_Ohio - 11/17/19 09:05 PM
Walker mower Oil
by Joey737 - 11/17/19 09:03 PM
Rough service tough light bulb 1ยข at Home Depot
by JLawrence08648 - 11/17/19 08:40 PM
2015 F150 5.0 8592 miles
by Buzzinhalfdozen - 11/17/19 08:36 PM
MOPAR MO-285 FACTORY OIL FILTER CUT OPEN
by 53' Stude - 11/17/19 07:43 PM
Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
Grumpy Kid
by wings&wheels - 11/17/19 01:57 PM
h9/95R FLA Batteries
by TXCarGeek - 11/17/19 01:40 PM
Preventative parking brake service
by Donald - 11/17/19 01:26 PM
JimBobSeeker, Joey737, bdavis218, XTR74, 2009Caraman
69899 Registered Users
27 registered members (carlprop, ctechbob, cjolson140, BrandonT, aleneros, 2 invisible), 788 guests, and 18 spiders.
Topics297,569
Posts5,118,190
Members69,899
Most Online3,589
Nov 2nd, 2019
Page 1 of 25 1 2 25
Post Your Latest Coolant Change. #2261994 05/15/11 05:45 PM
6
660mag Offline OP
6
I looked way down the pages for another post like this and came up with nothing... so here we go.
1997 Jeep Grand Cherokee 4x4
318 cdi.
out: a two year old mix of who knows what.
Water flush only.
In: 3gal O'reillys extended life universal formula.
Re: Post Your Latest Coolant Change. [Re: 660mag] #2262012 05/15/11 06:00 PM
E
electrolover Offline
E
04 explorer around 100k
out:factory fill
flushed with water and prestone flush.
in: prestone all makes all models 2 gallons + 2 gallons water(from a hose!)
04 f150 around 130k
out: factory fill
flushed with prestone flush and water
in: prestone all makes all models 2 gallons+ 1 1/2 gallons water(from hose)
Re: Post Your Latest Coolant Change. [Re: 660mag] #2262038 05/15/11 06:16 PM
W
WANG Offline
W
2007 BMW F800S
Out: 4 year old factory fill
Flush: None
In: 50/50 Pentosin Pentofrost NF + distilled water
"Sportbikes have evolved from an axe into a scalpel.
Problem is, the average sportbike buyer is more lumberjack than surgeon." -Richard Pollock
Re: Post Your Latest Coolant Change. [Re: 660mag] #2262057 05/15/11 06:47 PM
T
Towncivilian Offline
T
2001.5 Pathfinder at 121,645 miles on February 27th, 2011
Out: Genuine Nissan coolant, about 30k old. Dealer flushed @ 90k
Radiator drain & fill
In: 50/50 Genuine Nissan + distilled water (1 gallon each)
Overflow reservoir had a lot of sediment in it. I flushed that using one gallon of distilled water by bringing its hose lower than the reservoir.
2001.5 Pathfinder SE 3.5L A/T 2WD - ML NG 5W-30/PL14610
2007 Altima S - PU 5W-30/M1-110
2009 G5 - PU 5W-30/XG9018
2012 G37 S - ST 5W-30/PL14612
Re: Post Your Latest Coolant Change. [Re: 660mag] #2262088 05/15/11 07:21 PM
P
pzev Offline
P
03 Ford Focus
Out: Zerex G-05 (I drain the rad every 30k)
In: 50/50 Zerex G-05 + distilled
89 Toyota Camry
Out: Who knows what...(rad replacement)
In: Zerex G-05 + distilled
89 Honda Accord
Out: The rustiest nastiest looking coolant on earth
In: MULTIPLE flush solutions (Preston flush and heavy duty rad cleaner) + distilled. Rinse and repeat. On my 6th drain and refill + one power flush with a hose. This is going to be the last cycle before I put coolant in. Zerex G-05 will be the coolant.
2016 Ford F150 5.0 w/ Roush Supercharger
2012 Ford Mustang 5.0 (soon to be sold)
Re: Post Your Latest Coolant Change. [Re: 660mag] #2262089 05/15/11 07:22 PM
DaHen Offline
On a 2006 Altima 2.5 with 20,000 miles:
Drained and refilled the radiator only with 50/50 distilled water and Nissan brand coolant.
'06 Altima
ECHO: PB-255LN Blower
Husqvarna: 445E 18"/20" Chain Saw
McCulloch: Electramac EM300S 16" Chain Saw
John Deere: TRS-26 Snow Blower
Craftsman, (Husqvarna in disguise): 22" Lawn Mower
Re: Post Your Latest Coolant Change. [Re: DaHen] #2262150 05/15/11 08:48 PM
H
Hallmark Offline
H
Since coolant requirements may (and most likely are) extremely critical to engine construction (i.e aluminum and/or iron), waterpump seals, and other cooling system components as reflected in manufacturer's coolant specs, I'm wondering why you post this inquiry.
A proper coolant selection is based on specifics of the application, not on popularity or consensus reflected in a poll.
Re: Post Your Latest Coolant Change. [Re: Hallmark] #2262202 05/15/11 09:46 PM
E
E
imnot sure but maybe its just a thread to brag about taking care of our cars and im ok with that smile
Re: Post Your Latest Coolant Change. [Re: 660mag] #2262265 05/16/11 12:12 AM
M
mongo161 Offline
M
I'll most likely drain the old coolant out....Green SuperTech....and run a couple of fills of distilled water....drain and fill with a 50/50 mix of SuperTech Antifreeze/Coolant and distilled water.
I've been using the SuperTech for the past few fills....and no problems to report.
I get by with a little help from my friends....listen with your eyes....it's the ONLY way to believe what you hear...
Re: Post Your Latest Coolant Change. [Re: 660mag] #2262354 05/16/11 06:56 AM
T
Trav Offline
T
2000 GM 3800.
Replaced all hoses with Gates ECR hoses and new GM thermostat.
Flush refill with 6qts John Deere Coolguard original formula and 6 qts distilled water.
Re: Post Your Latest Coolant Change. [Re: Hallmark] #2262402 05/16/11 07:40 AM
6
660mag Offline OP
6
I'm sure most oems would say the same for engine oil.
Making a sound choice for your coolant selection is not that hard, and in most cooling systems there's more than one brand/coolant type sufficient for protection and system durability.
Note: many cooling system failures have still occurred while
following oem recommendations.
Plus it's another reason to visit the site.
Re: Post Your Latest Coolant Change. [Re: mongo161] #2262606 05/16/11 11:14 AM
M
mongo161 Offline
M
IMO....The WalMart SuperTech Cooant is the same as the PEAK long life Coolant. Looks the same and performs the same.
Re: Post Your Latest Coolant Change. [Re: 660mag] #2262726 05/16/11 01:01 PM
R
rslifkin Offline
R
Last summer, I drained the old green out of the Jeep (the one in my sig), flushed it with lots of distilled water, and refilled with G-05. Seems to have broken some stuff loose in the system, as the coolant is getting a bit cloudy, so I'll do it again in a couple of weeks.
Flushed the nasty dex-clone / green slop out of my Mom's 99 Grand Cherokee 4.0 with distilled water and replaced with G-05 a few months ago. Definitely going to flush that one again.
1998 Jeep Grand Cherokee 5.9 Limited with lots of mods (225k miles, bought with 100k in 1/2010)
Rotella T6 @ 6k OCI
Re: Post Your Latest Coolant Change. [Re: rslifkin] #2263744 05/17/11 01:12 PM
cos Offline
I prefer to use factory fill-
1)'02 Escape - radiator drain 'n fill with Peak Original Green formula/distilled water
2)'06 Fusion - radiator drain 'n fill with Motorcraft Gold (aka: Xerex G-05)/distilled water
'15 Cadillac SRX
- Castrol Magnatec 5W30
- Valvoline Maxlife ATF
Re: Post Your Latest Coolant Change. [Re: 660mag] #2264359 05/18/11 12:49 AM
SOHCman Offline
99 taurus, out with green something, and in with peak "conventional" green.
I urge people not to wait 100K to change out the fluid in their transfer case units. -Kestas
Page 1 of 25 1 2 25
