The background:
My buddy had been wanting to buy a second 4wd tractor as back up to his primary. On the day he went to pick it up from the seller (a buddy of his) he (seller) found coolant in the oil. So, he did a liner kit on the wounded cylinder, re-conned the rod and stuck a new rod bearing in. Buddy picks the tractor up (IH 4366)- actually I drove it home while he followed. Got it rigged for his equipment and went to the field... About 8 hours later the engine lugged down and when he punched the clutch in, it shut off. Rut-roh... He got out, did a walk around and found nothing amiss. Hopped up in the cab and hit the starter. Fired up... Finished his work and took it home. I was out the next and was getting ready to take it out myself. When it started, there was a definite knocking noise...
Here's what the autopsy revealed... #5 (the same hole that was kitted) was D.O.A. again.
We're thinking that the injector is toast and dumping fuel. Now it's time to kit all six holes and replace the injectors... He's a parts guy, so he'll get a good deal on piston kits and injectors too...
I was amazed at how easy it was to tear apart. I had it done in a couple of hours, not trying too hard.
