Originally Posted By: Artem
Originally Posted By: ltslimjim
I definitely believe you got the life out of the oil you should want. I'd cap it at 5,000 for now and re-sample. I don't like the TBN past 2 and the TAN starting to climb. I'd be curious about a TAN number after another run as well.
Monitor sodium, coolant level etc, otherwise wearing about the same as before.
I wonder if some sodium has been added to their formulas(some of them?) to aid in anti-foaming ever so slightly??? Here's me hoping in case my sodium doesn't trend down, but I had used Valvoline before so we'll see.
Note: 1,000 miles and no coolant consumed yet for me.
Your silicon increase is probably a direct result of the VCG repair. Nice report.
Although i agree that i got pretty good value outta the cheap OE oil after 5k i feel it can go longer (look at the 7k previous run)
I plan to run the XL line after this last 5k run with OE to compare wear numbers, TBN, etc. I'm hoping the extra "Boost" in XL will show up in the UOA.
We bought the Camry New in 97 as a 98 model and after basically 14 years of problem free use, i feel i got pretty darn good value outta the car and dont really care about the wear numbers as much at 200k.
I feel the "slight" bearing wear won't be a problem with a good quality oil and a relatively easy daily commute (mostly highway) for another 100k worth so i want to use the car as an experiment platform and extend the OCIs to the limit. haha.
I think 10k is do-able with Amsoil OE based on the previous 7k run...
Nice, I see where you are heading with this. Oh, and thanks for showing the UOAs of the used oil in the other application. It's cool you have the ability to do this much.
