I operate a JD 755 which is a small tractor with a hydrostatic trans. It specs Low viscosity hy-gard fluid. The manual also states that ATF can be used if it meets M2C33F (Type-F). The low-vis fluid is always hard for me to find. Do any of you guys think that the ATF might be a better choice? Any ideas why type-f? I have used the regular Hy-gard but I got a lot of whine from the hyd pump. These are all the specs I can find on the JD fluid. Thanks Chemical and physical properties: Hy-Gard
Low-Viscosity Hy-Gard
Viscosity
40 degrees C
33
100 degrees C
7.1
Pour Point
-51
Flash point (min.)
180
Total base no.
13
Viscosity index
195
Viscosity
40 degrees C
33
100 degrees C
7.1
Pour Point
-51
Flash point (min.)
180
Total base no.
13
Viscosity index
195
