Forums Migration
Please read this thread
EP additive?
by CCI - 07/10/20 11:06 PM
Kawa FR600V Oil
by Propflux01 - 07/10/20 10:34 PM
Dexron VI for 700R4.
by jakewells - 07/10/20 10:22 PM
Picked Up the DeWalt Mid Range Impact
by Fringe - 07/10/20 09:42 PM
Checking out neighbours lawn mower
by Snagglefoot - 07/10/20 09:19 PM
TV help needed
by ffhdriver - 07/10/20 09:00 PM
FS Solar panels PU only 250w $80
by BeerCan - 07/10/20 08:29 PM
Ford Easy Fuel
by buck91 - 07/10/20 08:27 PM
Oil for the track
by lowon - 07/10/20 07:34 PM
Bought a grapple
by Ausfahrt - 07/10/20 06:30 PM
What is this charger for?
by CharlieJ - 07/10/20 05:58 PM
World War II movie Greyhound
by skyactiv - 07/10/20 05:48 PM
GC for Fuel Dilution - Accuracy
by Gene K - 07/10/20 05:21 PM
How Do I Get This On?
by Gebo - 07/10/20 05:08 PM
Creativity Suggestions?
by maverickfhs - 07/10/20 03:18 PM
3.5 Ecoboost Oil, I've decided.
by Gene K - 07/10/20 02:07 PM
Mopar Extended Warranty with 100% Refund Option
by The Critic - 07/10/20 12:46 PM
The great lakes are warm!
by OVERKILL - 07/10/20 11:38 AM
SUmeme22, DaveCaddell, SharkNC, Puckster02, TurbodogTodd
71907 Registered Users
57 registered members (ajchien, 4WD, bbhero, 2015_PSD, 92saturnsl2, another Todd, 5 invisible), 1,125 guests, and 34 spiders.
Topics307,708
Posts5,316,183
Members71,907
Page 2 of 4 1 2 3 4
Re: Viscosity spread & VI vs shearing [Re: dparm] #2226525 04/08/11 07:59 PM
dparm Offline OP
I was hoping to find the HTHS for the motorcycle 300V 10w40, as it's probably really close to the auto (I saw this with the 5w40). Unfortunately the data doesn't seem to be published.
2017 Chevrolet Corvette Grand Sport
Re: Viscosity spread & VI vs shearing [Re: CATERHAM] #2226537 04/08/11 08:09 PM
dparm Offline OP
Originally Posted By: CATERHAM
Originally Posted By: A_Harman
One thing that struck me as odd when I was looking at the Motul PDS's, was they didn't list HTHS for the 10w40 300V. I took that as meaning it is about the same as the 5w40.
It's 4.19cP and it's listed here:
http://www.motul-canada.com/en/products/...o_10W40_TDS.pdf
But I think that must be a misprint as it's lower than the 5W-40's 4.51cP. I always thought that was way too high for a 176 VI, KV100 13.8cSt oil.
I think the 161 VI 10W-40 has the 4.51cP HTHS and the 5W-40 the 4.19cP HTHS vis'; that makes a lot more sense.
If someone really wants to know, send me a gallon of each and I'll be more than happy to confirm it!
Realistically how much do you need to determine the HTHS?
Re: Viscosity spread & VI vs shearing [Re: dparm] #2226660 04/08/11 10:07 PM
chubbs1 Offline
CATERHAM, thanks for the good info.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
Re: Viscosity spread & VI vs shearing [Re: dparm] #2226674 04/08/11 10:28 PM
M
mechanicx Offline
M
I'm no oil expert but if we assume the 10W40 and 5W40 have the same base oil and differing VI, lower VI for the 10W40 and higher for the 5W40, I would say that to get that high of a VI index(~200) the 5W40 must contain some VI improvers and has a lighter grade base oil. If I'm recalling the specs right the 5W40's higher volatility and lower flash point support that interpretation.
I think the 10W40 would be the more grade stable and better choice for warmer temperatures and racing. I'm thinking you can't get a VI much over 170 or a grade "spread" over 20 ie (10W30)maybe 30 without VII's no matter if the base oil is ester. I know grade "spread" is kind of dubious.
Both oils are probably pretty sheer resistant, but fuel dilution can also shear VII and fuel dilution is a possibility when running at power enrichment.
Re: Viscosity spread & VI vs shearing [Re: dparm] #2226686 04/08/11 10:36 PM
dparm Offline OP
The first 2000 on the oil didn't show much fuel dilution, even with a track day and several autocrosses. The car is not direct-inject.
Re: Viscosity spread & VI vs shearing [Re: dparm] #2226692 04/08/11 10:43 PM
M
mechanicx Offline
M
Fuel dilution would probably be more of an issue for short trip driving where the oil never warms up. I still wouldn't totally discount fuel dilution causing some slight loss of viscosity when VII are used. It seems B-S almost never reports fuel dilution while other oil analyzers seem to report it more often. Either way I don't think it is going to be mnuch of an issue with those two oils.
Re: Viscosity spread & VI vs shearing [Re: dparm] #2226701 04/08/11 10:51 PM
dparm Offline OP
Well my car is also a DD here in downtown Chicago. 300V's high TBN and TAN are supposed to be good at handling fuel dilution. The 11L sump doesn't hurt either...
I'll stick with the 5w30 for this next change and get another UOA to see how it holds up versus the 5w40.
Re: Viscosity spread & VI vs shearing [Re: dparm] #2226794 04/09/11 02:48 AM
CATERHAM Offline
The difference in HTHS values between Motul 5W-40 and 10W-40 is 0.32cP. That should represent something like a 10 psi oil pressure difference at elevated rev's if the two oils were tested in an OP equipped vehicle.
Having said that, I'm certain the 300V 5W-40 has a HTHS vis no higher than 4.19cP; that's impressive enough for a KV100 13.8cSt oil.
-'74 Lotus Europa, 5W-50 & VSOT
-'96 BMW 328i, 50/50 TGMO 0W-20/M1 0W-40
-'94 Caterham 7, FUCHS 0W-20
-'18 Tesla Model 3 - FF diff' oil
Re: Viscosity spread & VI vs shearing [Re: dparm] #2226862 04/09/11 07:20 AM
B
buster Offline
B
The simplest method is still the best. Divide the kinematic viscosity @100C (in Cst), by the HT/HS viscosity. The lower the number the better.
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: Viscosity spread & VI vs shearing [Re: buster] #2227000 04/09/11 11:54 AM
CATERHAM Offline
It's not a bad "blind" predictor of oil shear but simply knowing something of an oil's chemistry and VI level is still the best.
For example M1 0W-40 has a shear factor of 3.55 (13.5/3.8)and the Toyota 0W-20 has a better shear factor of 3.38 (8.8/2.6).
But the Toyota oil definitely shears more than the M1 oil.
That's not surprising since the Toyota 0W-20 has a 214 VI and is a GP III based oil.
Re: Viscosity spread & VI vs shearing [Re: dparm] #2227013 04/09/11 12:25 PM
A
aquariuscsm Offline
A
That`s always made me wonder if there would be any benefit using monogrades (an SAE30 in the winter and an SAE40 in the summer)?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
Re: Viscosity spread & VI vs shearing [Re: aquariuscsm] #2227076 04/09/11 02:07 PM
CATERHAM Offline
Zero benefit in both winter and summer.
Re: Viscosity spread & VI vs shearing [Re: CATERHAM] #2227202 04/09/11 04:40 PM
A
A_Harman Offline
A
I've been doing a more involved calculation to get a feel for the shear resistance of an oil:
1. Plug the KV40 and KV100 numbers into the Widman Operational Viscosity calculator, and calculate a KV150 number.
2. Take the density at 15C, and multiply by 0.9 to get an estimate for density at 150c.
3. Multiply the numbers from steps 1 and 2 to get a dynamic viscosity at 150c.
4. Divide HTHS by the DV150 number from step 3. This gives the fraction of HTHS to the expected dynamic viscosity of an oil at 150C. The higher the better. POE oils such as Redline and Motul are pretty close to 1.0.
2008 Dodge Ram 3500 diesel/G56
1985 Z51 Corvette track car 355/6-speed
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel/NV4500+GV
1972 GMC 1500 shortbed project truck 307/SM465
Re: Viscosity spread & VI vs shearing [Re: dparm] #2227426 04/09/11 07:50 PM
dparm Offline OP
<--- Fires up Excel....
Re: Viscosity spread & VI vs shearing [Re: dparm] #2228005 04/10/11 11:44 AM
dparm Offline OP
It's in Google Docs now!
https://spreadsheets.google.com/ccc?key=...uthkey=CMOmna4P
You might be right about the incorrect 10w40 vs 5w40 HTHS values provided by Motul, CATERHAM. The 10w40 is technically the LEAST shear resistant of all the 300V varieties, according to A Harman's formula.
BTW I threw everyone's favorite, GC, in there for grins. I had to use the estimated HTHS of 3.5 and an approximate density @ 15C of 0.88. Also threw in M1 0w40 since that's another high-quality OTS oil. Surprisingly, GC and M1 have almost the same shear resistance. Few some others in there like RLI and Redline, too.
Page 2 of 4 1 2 3 4
