At work we just changed from Gumout Fuel Injector Cleaner setup, which injects a liquid in through a vacuum line to clean the intake valves along with a tank dose to a new Valvoline setup. The Valvoline setup has a 'Smoke-Free Intake cleaner' which goes in through a vacuum line just like the Gumout but does not smoke like the Gumout did. When the Valvoline Rep was talking, he said, "this is a detergent based cleaner; it doesn't use solvents to clean like the Gumout." This peaked my interest, so I went and looked up the MSDS.
It lists:
Solvent Naptha 64742-89-8 >=60- Cyclohexanone 108-94-1 >=10- Diethylene Glycol Monobutyl Ether 112-34-5 >=10- Methyl-N 2-Pyrrolidone 872-50-4 >=5- Xylene 1330-20-7 >=1.5- Ethyl Benzene 100-41-4 >=1-
Seems to me "Solvent Naptha" is a solvent..right?
It also comes with a bottle for the tank which has:
Hydrotreated Heavy Naptha 64742-48-9 >=80- Distillates, Sweetened middle 64741-86-2 >=1.5- Solvent Naptha 64742-94-5 >=1.5- Napthalene 91-20-3 >=0.1-
Which seems kinda lame to me. What do you guys think?
It lists:
