Tractor: 1962 Case 630. In-line 4 cylinder.
It was running fine, shut it off, tried to restart, isn't firing.
Got out the test light, and with the key in the run position, the test light works all the way to the one side of the points.
However, I don't think I'm getting any spark jumping between the points when I crank. (It's too bright outside to see). I'll try to get a tarp to block the sunlight, to verify that.
What else do I need to check? Of course, it is sitting in a really bad spot.
