Air Fryer....whose got'em?
by Schmoe. 01/16/19 01:59 PM
ebates - anyone a member?
by Papa Bear. 01/16/19 01:29 PM
Ordered a 2019 X5 for the Wife
by gofast182. 01/16/19 12:48 PM
Today, I ride
by SirTanon. 01/16/19 12:02 PM
2019 Nissan Rogue SL
by JTK. 01/16/19 11:19 AM
Does GM oil life monitor % go down without driving?
by Corollaman. 01/16/19 10:37 AM
Ford tire wear issues?
by Redright9. 01/16/19 10:23 AM
New Battery
by CarlGR. 01/16/19 10:21 AM
It's January and I Need My Motorcycling "Therapy" !!
by LoneRanger. 01/16/19 10:13 AM
Are New Vehicles Too Expensive?
by SubLGT. 01/16/19 10:02 AM
Manual transmission fluid in Europe for Mazda
by zsero. 01/16/19 07:31 AM
Affected by the gov't shutdown?
by xBa380. 01/16/19 07:04 AM
Opinion Needed / 1998 Olds 88
by Mark72. 01/16/19 06:24 AM
Chevron Supreme color change
by OilUzer. 01/16/19 05:14 AM
Dual exhaust benefits
by OilUzer. 01/16/19 03:02 AM
M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
The best in personal defense (Humor)
by StevieC. 01/15/19 11:10 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
98 registered members (4WD, 28oz, 53' Stude, 240_Ed, 97f150, 9 invisible), 2,220 guests, and 34 spiders.
Topics296,643
Posts4,956,493
Members66,950
Most Online2,577
Jan 14th, 2019
How long before a filter goes to bypass? #2219241
04/01/11 07:37 PM
04/01/11 07:37 PM
Ontario
Magnatic Offline OP
Magnatic  Offline OP
Ontario
I was speaking with an owner from a oil change shop who stated that most oil filters start to bypass at approx. 4,000 miles due to clogged filter media. I understand that he has an obvious bias and his statement was a broad generalization when in fact, there are many variables that come in to play. However, in general terms, how long should a filter be used?
Secondly, do manufacturers take oil filter life into account when determing the length of OCI's?
Thank you.
Re: How long before a filter goes to bypass? [Re: Magnatic] #2219266
04/01/11 08:08 PM
04/01/11 08:08 PM
In The Region Between
Cristobal Offline
Cristobal  Offline
I suppose it depends on the dust load. I wonder if people who use the higher end synthetics just change the filter, but not the oil, now and then.
Surrounded by ferocious, snarling, & spoiled Poodles!
Re: How long before a filter goes to bypass? [Re: Cristobal] #2219280
04/01/11 08:28 PM
04/01/11 08:28 PM
Northern BC, Canada
mva Offline
mva  Offline
Northern BC, Canada
Yes, manufacturers take into account filter life and plugging when they specify oil change intervals. Honda currently recommends changing the filter every second oil change.
A filter might be in bypass when you first start the engine with cold thick oil.
Once the oil fully heats up it would have to be severely plugged to still be in bypass.
I have run filters out to 20,000 plus km and the media is black but not plugged to the point where I would be concerned about bypassing. As the media starts to fill and plug the filter efficiency actually rises.
Also, you can typically cross reference a longer filter for many vehicles. For example, I am running a TG3600 filter on my Toyota which is about 1 1/2" longer and has significantly more media than the recommended TG3614.
2014 Ford F150 Ecoboost 19,000km Motocraft 5W30 oil
Re: How long before a filter goes to bypass? [Re: Magnatic] #2219281
04/01/11 08:29 PM
04/01/11 08:29 PM
Merritt Island FL, USA
chubbs1 Offline
chubbs1  Offline
It is a good question but many variables make it hard to answer specifically. If we take a well maintained engine and a properly working filter (no defects), the size of the filter matters because more media more dirt it should hold, thus extending life. Bottom line is your filter should be purchased with the amount of time your expected OCI will be. So if you go to Your auto store and buy the premium oil/filter special it should get you through the whole OCI. So GENERALLY you get what you pay for. If you buy a Bosch Distance Plus, you should get an easy 10K. If you buy a $2 Pronto I would lessen my expectations. Also as Christobal said, you can buy cheap filters and change them out at 3-4K. Tough one, bottom line is don't be cheap with filters and if you are going to be, expect to change sooner.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
Re: How long before a filter goes to bypass? [Re: Magnatic] #2219327
04/01/11 09:05 PM
04/01/11 09:05 PM
Cocoa, FL
ahoier Offline
ahoier  Offline
Cocoa, FL
I'd think there's a time during a vehicles life too, where the filter would be less-susceptable to dirt/filling up.
Obviously, during break-in on a newer engine, I'd think you'd see more wear, as the parts all start to "seat" properly.
But yea, all would depend on your filter, and the vehicle really, how long it takes before it gets completely clogged, and thus thrown into "bypass" mode....
On a side note; the Hayne's manual for my 88 Dodge Aries recommends changing the oil filter every-other oil change....:) So, I can't see the whole "clogged filter" excuses being that big of a deal.
But of course, this edition was written back in 1992 if I recall....we all know now you may as well just change out the filter when you change the oil, since you gotta go under the car anyways....
and actually, not even :P Mine is easily do-able from the top end hehe, just a matter of getting a small drain pan down there between the radiator hose(s).....so it doesn't leak all down the front of the engine when the filter is removed.
Sure, it'll make it easier removing it from underneath, but not totally mandatory.
Re: How long before a filter goes to bypass? [Re: Magnatic] #2219336
04/01/11 09:15 PM
04/01/11 09:15 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
It would take a lot of crud to make a filter go into bypass. I have cut M1 filters apart with 15K on them using M1 5-30EP and they were very clean. Also XM says no special filter is required for their EP oils going 15K. Now of course that would be for engines that were clean to start with.
2007 Ford Fusion 236,000 miles
M1 0-20 EP
2017 Ford Fusion 62K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: How long before a filter goes to bypass? [Re: Magnatic] #2219365
04/01/11 09:45 PM
04/01/11 09:45 PM
Lake Forest, CA
HTSS_TR Offline
HTSS_TR  Offline
Lake Forest, CA
I didn't cut open any spin on filter, but I did look at the E430 cartridge paper filter after 13-14k miles and found nothing on the media to suggest that it may be in bypass for clogged media.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
Re: How long before a filter goes to bypass? [Re: mva] #2219370
04/01/11 09:56 PM
04/01/11 09:56 PM
Pacific Northwest
Hallmark Offline
Hallmark  Offline
Pacific Northwest
Not to be argumentative, but how do you determine that the media is "...not plugged..."?
I've visually examined various filter media for over 50 years and I cannot distinguish between media with 5k or 15k miles of service.
Re: How long before a filter goes to bypass? [Re: Magnatic] #2219377
04/01/11 10:09 PM
04/01/11 10:09 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
This ISO test method would tell the whole story. Anyone here have an actual full blown copy of the test standard? It cost big bucks to download it from the internet.
ISO 4548-12:2000
Methods of test for full-flow lubricating oil filters for internal combustion engines -- Part 12: Filtration efficiency using particle counting, and contaminant retention capacity.
This part of ISO 4548 specifies a multi-pass filtration test with continuous contaminant injection and using the online particle counting method for evaluating the performance of full-flow lubricating oil filters for internal combustion engines.
The test procedure determines the contaminant capacity of a filter, its particulate removal characteristics and differential pressure.
This test is intended for application to filter elements having a rated flow between 4 l/min and 600 l/min and with an efficiency of less than 99 % at a particle size greater than 10 microns.
Re: How long before a filter goes to bypass? [Re: Magnatic] #2219447
04/02/11 02:25 AM
04/02/11 02:25 AM
Pottstown, PA
Gary Allan Offline
Gary Allan  Offline
Pottstown, PA
It would take an extremely saturated filter to be in bypass all the time. What would occur is that it would have elevated differential pressure longer as the oil thinned.
Yes, engine man's take everything into consideration, that's why non OLM (includes even less articulate systems) equipped vehicles give a time/mileage recommendation. This allows the "every other" filter change IF mileage is used (for some man's over some years +/-)
So, 15k/year ..lots of hollow miles out of fuel enrichment ..hardly any filter loading going on.
Oddly ..some get this wrong ..but not with filters. Let's say it's 7500/6months ..some forget the "whichever comes first" and just say that they're using the mileage method ..even if it takes 7-8-9 months to accumulate.
Re: How long before a filter goes to bypass? [Re: Magnatic] #2219782
04/02/11 12:22 PM
04/02/11 12:22 PM
Washington St.
Ken2 Offline
Ken2  Offline
Washington St.
The filter goes into bypass the very first time you start it with a new filter and new cold oil.
As to when the filter is so clogged that it bypasses with normal hot oil, it will be a very long time. Oil analysis tests for insolubles (and an extra cost test for particulates is available) and these do not show higher quantities unless there is a specific problem with the engine or the environment. I run my filters 10,000 miles with good tests and great engine wear results...112,000 miles on my Tundra and 190,000 on my turbo Volvo, and both are tight and strong with excellent annual oil analyses.
Re: How long before a filter goes to bypass? [Re: Ken2] #2219793
04/02/11 12:32 PM
04/02/11 12:32 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
I doubt that unless you started the engine with the gas pedal to the floor. The oil pump isn't putting enough oil volume out at idle to make a new filter go into bypass unless the oil viscosity was like honey.
Re: How long before a filter goes to bypass? [Re: Magnatic] #2220134
04/02/11 05:33 PM
04/02/11 05:33 PM
ks, wichita
morris Offline
morris  Offline
ks, wichita
IMHO its the dirt not the miles
Re: How long before a filter goes to bypass? [Re: Hallmark] #2220158
04/02/11 06:01 PM
04/02/11 06:01 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
We're talking about a lot of visable sludge in a filter from a very dirty engine.
M1 0-20 EP
M1 0-20 EP
M1 10-30 in all OPE
MC filters
Re: How long before a filter goes to bypass? [Re: Magnatic] #2220201
04/02/11 06:51 PM
04/02/11 06:51 PM
ks, wichita
morris Offline
morris  Offline
ks, wichita
just what we need an OTHER standard.
