A couple of days ago I was doing an OC on my mower and I went ahead and decided to use the blower to clear off the debris left from last fall. The blower is a Ryobi (2-cycle) that is about 5 years old.
The blower started OK but never would get "up to speed". After turning off the choke and letting it warm up it just sounded like it was only about half speed and didn't have the whining sound it should. I shut it off and put fresh gas in it, but it still ran the same way. I remember last year it seemed like it was taking longer and longer to run normally.
Here's what I'm concerned about: Last Fall I noticed that the blower wheel (impeller) seemed to be fairly wobbly and would get very hot to the touch. I had used the blower as a vacuum last Spring to pick up the trillions of Maple (aka weeds) "helicopter" seed and apparently in the process of mulching them up a significant amount of fine, wet buildup got on the impeller and housing (for some time after that, while using it as a blower it would spit chunks of what looked like dirt). Is it possible that the junk on the blower/impeller might have put it out of balance and caused damage to the bearings - resulting in "drag" in trying to rotate the shaft? Or would it more likely be a fuel mixture type problem?
