I just finished a transmission filter change and offline flush on my 1998 Exedition with the 4R100 Transmission.
I used Valvoline Dex/Merc Max Life.
The transmission shifts smoother and better than ever and I am really happy with the immediate results.
I do however have a couple new problems since the fluid change.
Has anyone heard of the following issues?
1) A quick decelleration will ocassionally cause the vehicle to stall when approaching stop.
2) When I shift the selector into low gear while at a stop, the rpm's drop significantly and will ocassionally stall the vehicle.
3) This condition sometimes happens shifting into reverse as well.
Also changed fuel filter and PCV Valve at the same time.
Should also note that there is a rust hole in the filler tube (Don't know if there is any relevance.)
