Just talked with Toyota factory line and was told Toyota's only two requirements for my late model 4Runner that comes with red, are; don't use an alcohol based coolandt, dont' use straight water.
Either this guy is misleading me or Toyota does not care one way or the other.
This call was prompted by a dealer that said the red color is only there to let the service guys know if your first coolant change was made, as they use green coolant for all radiator flushes.
The more I read the more confused I get. The sure answer is to lay down for the expensive red coolant.
