Originally Posted By: mechanicx
I have no comment on whether exhaust bolts get annealed or soften or not, but I've never drilled out any bolt, in general and not just exhaust, that I thought was easy. I just look at bolts as harden steel and hard to drill through even with a cobalt bit. I suppose if you heated a bolt with a torch and let it cool slowly it should be softer but I can't really tell.
I've tried that, and in my experience it actually makes the bolt harder. Heat gets conducted away from the bolt pretty quickly... it's hard to make it cool down 'slowly'. I guess with the application of enough heat over enough time, it might be possible- but I've never been able to do it.
For removing broken bolts in general, my preferred method is to remove the part and mount it on a drill-press... then it'll usually come out easily enough. But if removing the part isn't an option, I'll usually square up the end of the bolt with a carbide burr on a die grinder, then center-punch it so I'll get a straight start, and start drilling it out with successively larger left-hand cobalt bits. With luck, that left-hand bit will grab the bolt and spin it out- although that rarely happens with exhaust bolts. Sometimes I keep drilling it bigger until I can remove the remaining threads with a chisel and clean up the hole with a tap. Sometimes that doesn't work and I just go ahead and drill the hole out bigger and fix it with a heli-coil or the like.
For a worse-case scenario where the drill bit gets crooked and off-center, and the bolt hole is mangled beyond repair (hasn't happened to me for years, but I have to clean up other guys' messes on occasion), I have a fix that some of ya'll might find amusing. And old-timer at a Cummins dealership showed me this. I'll go ahead and drill out the hole a little bigger, and tap it for the closest size pipe thread. Then I'll install a solid pipe plug good and tight with some green locktite- a cast iron plug for cast iron, an aluminum plug for aluminum, etc. Then grind off the plug flush with the surface, re-locate, re-drill, and tap the hole. It makes for a nice, functional repair.
